Old 07-19-2009, 10:37 PM   #1
Equal-i-zer or dual cam
What are the advantages of either of these 2?
The equalizer square bar setup or the rees straight line dual cam setup?
edman87k5 is offline   Reply With Quote
Old 07-20-2009, 06:08 AM   #2
jaxfl's Avatar
I owned 3 TT and I used the equalizer on all. It seemed easier to me to hook up and took care of sway as well as weight distribution. I never used the dual cam so can't comment on it.
jaxfl is offline   Reply With Quote
Old 07-20-2009, 07:00 AM   #3
Head Rambler
I have the Equal-i-zer and have helped set up several Dual-Cam units. It's really one of those 6 of one, half dozen of the other things. They're both good units and set up properly, they both do an excellent job. To me the Equal-i-zer is a bit easier to set up but it makes more noise when turning etc, than the dual cam does. The dual cam is easier to snap up into the brackets than the Equal-i-zer but if you have an electric tongue jack it's a non issue.
Gotta go campin!
Old 07-20-2009, 09:23 AM   #4
MtnGuy's Avatar
I use the Dual Cam, and my trailer tows sweet. A properly set up Dual Cam will keep you in a straight line going down the road, where I would think the Equalizer will tend to keep your combo at the last turn angle (never used an Equalizer, so this is speculation). I do notice with my Dual Cam when approaching a curve, that my truck wants to go a little straighter than without the trailer, but is easily overcome (classic understeer ??).
The Dual Cam is plenty noisy, even with Vaseline on the cam lobes.
Beware if you get the trunnion bar setup with the Dual Cam. If you have a 6" tongue frame, and the coupler is welded on top of the frame, there could be a spring bar rub against the cam yoke, or frame plate bolt. I had to go with a 1" raised ball to clear the frame plate bolt, and it still rubs the yoke during a hard turn. This doesn't happen with a 5" or less frame, the coupler welded to the bottom of the tongue frame, or the round bar setup.
Old 07-20-2009, 09:41 AM   #5
I also have the Dual Cam Reese setup, and it is noisy, as well. It does keep sway in check very well, however. And I have an electric tongue jack, so hooking up is not too hard. I think Reese has been in the towing equipment business longer, which is why I went with them. I don't know anyone with the equalizer set up for comparison. Randy
Old 07-20-2009, 04:56 PM   #6
acadianbob's Avatar
I have the dual cam setup and get very little noise at all; not even lubed.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
equal-i-zer
