Old 08-12-2013, 08:57 PM   #1
Equal-I-zer question
A friend of mine gave me his old Equal-I-zer model 2332 12K hitch
My question is I own a 2008 Nissan pathfinder V6 with towing capacity of 6000lb and tongue weight of 600lb. My trailer is a 2001 Starcraft travelite hybrid with a 3260lb unloaded and 3990lb loaded. Will that hitch work???
AZRattle is offline   Reply With Quote
Old 08-12-2013, 09:03 PM   #2
Triguy's Avatar
I'd say no. Although the Equal-I-zer are made to work well with lower weights, I think 12,000/1,200 is too much of a difference for a 4K lb trailer.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-12-2013, 09:07 PM   #3
avolnek's Avatar
X2... It will work but not appropriately and you won't be happy with it...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-12-2013, 09:18 PM   #4
Twisty's Avatar
If you can find a pair of 600 lb spring bars for it, use it.
The 1200 pounders are far too stiff.
Call or Email them. Tell them what you've got and see if you can get the bars.
http://www.equalizerhitch.com/Contact%20Us/index.php
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 08-12-2013, 09:27 PM   #5
I used the same setup on a Starcraft hybrid and it weighed 3500 lbs. I towed it with a f150. It worked great.
chiro is offline   Reply With Quote
Old 08-12-2013, 09:47 PM   #6
+1 on Twisty's comment. You can get 600 lb bars easily and be a happy camper. Here's one place: Replacement Spring Bars for Equal-i-zer Weight Distribution Systems - Qty 2 - 600 lbs TW Equal-i-zer Accessories and Parts EQ90-01-0699
I hope I got the link correct. If not, just check out etrailer.com
00buck is offline   Reply With Quote
Old 08-12-2013, 10:09 PM   #7
twisty I sent Equal-I-zer an email, thanks
00Buck, your link works and if they recommend 600lb bars I will buy them, thanks.
Old 08-12-2013, 10:29 PM   #8
Twisty's Avatar
You're welcome, Friend
2012 Surveyor SV264
NW Oregon
Old 08-12-2013, 10:36 PM   #9
Grizzlygibbs's Avatar
Hitch heads and sockets are not interchangeable. I contacted equalizer and thy said smaller and larger bars are not interchangeable because the sockets they fit in are sized different, and the bars themselves are different as well. This is evident in hitch head model numbers and bar model numbers in the manual.
Your methods may vary but I sure would not do it!
Sell the 12k and get the size you want and need for your application.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 08-12-2013, 11:30 PM   #10
Twisty's Avatar
If that applies to the OP's free hitch...
that's a bummer.
2012 Surveyor SV264
NW Oregon
Old 08-13-2013, 12:23 AM   #11
That is at least what equalizer told me when I was I quirking about 10,000 bars for a 6,000 hitch head.
Old 08-13-2013, 07:33 AM   #12
Triguy's Avatar
Its also my understanding that the spring arms are designed for a particularly sized hitch head and cannot be used with a head of a different rating.
Scott
2012 Shamrock 233S
Old 08-13-2013, 08:09 AM   #13
another_newfie's Avatar
The hitch heads and the bars are not interchangeable. As others have suggested this setup will be far too stiff for your application.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 08-13-2013, 09:56 AM   #14
Thanks for all the replies, I received an email back this morning for them this mor
ning.
Hi Bobby
Thank you for contacting Progress Mfg
Our hitches do work well on lower weights, it would not harm you in any way to keep the 12K Equal-i-zer hitch on your little trailer, it is over kill but it is not going to affect your safety.
Have a great day!
Steve Binks
Progress Manufacturing 533 South 500 West Provo, Utah 84601 800-478-5578 x119 info@equalizerhitch.com
Old 08-13-2013, 10:06 AM   #15
avolnek's Avatar
ning.
Hi Bobby
Have a great day!
Steve Binks
Incorrect... It WILL affect your safety! The 1200 pound bars are not going to allow for much to any spring when you hit dips in the roads. At highway speeds this will result in porpoising or bouncing along the highway. This can become a HUGE safety factory as it can get violent enough to separate your vehicles tires from the pavement briefly... Sounds untrue but happens more than one would think...
You can use it, it will serve the purpose, but it will not work as it is supposed to. The choice is up to you but if you ask me the extra $300-400 for a new hitch appropriately sized would be well spent...
equal-i-zer
