Forest River Forums
Sunline User Photos
Old 08-28-2011, 09:53 PM   #11
Exactly turbo...THANK YOU MUCH......That's what I will try 1st then and see how that works. I had an extremely short tow when I brought it home, so I only used the spring bars and left the sway control off. Point being that I was not educated on how to hook them up.
Thanks for the advise.
BradW is offline   Reply With Quote
Old 08-28-2011, 10:10 PM   #12
too fast turbo sled
f1100turbo's Avatar
You'll find playing with the tightness of the friction bar makes a difference .
like I said try tight then back off a 1/2 turn if it seems like it swaying tighten a little.
I all ways took them off before backing or turning very sharp on a pull through site as well as the wdh bars .
When I pulled in to a cg I immediately took sway bars and wdh bars of as to not bind them when backing or turning sharp .
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 08-28-2011, 11:12 PM   #13
TYVM turbo..... I will heed your advice.....very helpful and much appreciated.
Old 08-30-2011, 10:01 AM   #14
thebrakeman's Avatar
The owners manual for friction sway controller will tell you to tighten the "on/off" bar all the way! It actually states that you should "bottom out the threads". That bar is not an adjustment feature. It's the on/off feature. Adjustment is made with the adjuster screw/bolt, which is about 2" above or below the on/off lever.
As far as removing before backing, that is not required. The instructions state that you should know your limits. If you don't know the limits, then it says the unit can be removed. Big difference. People think that backing and turning will damage the unit. This is not so. As long as you don't bottom out the unit in an extreme jacknife, there are no differences in forces on the unit when backing than when turning forward. It's when you bottom out the slider in the main housing that the unit acts like a solid beam, and can either damage itself, or part of the hitch head/drawbar.
When I used a friction sway controller with our old popup/minivan combo, I never removed it, and it never suffered any damage.
2004 Surveyor SV261T UltraLite Hybrid
thebrakeman is offline   Reply With Quote
Old 08-30-2011, 12:01 PM   #15
I need to look at my directions... My Dealer/Installer said to tighten the On/Off lever "2 finger tight"plus a little more! LOL, whatever that means! Thanks!
Chuck
2011 Coachmen Catalina 19RD
Days camped in 2011 - 22
Days camped in 2012 - 2 so far...
cbenslay is offline   Reply With Quote
Old 08-30-2011, 01:01 PM   #16
too fast turbo sled
f1100turbo's Avatar
i just read an article from propride about adjusting friction sway control .
1. SWAY CONTROL CANNOT BE USED ON TRAILERS WITH SURGE BRAKES. DO NOT USE SWAY
CONTROL ON CLASS I OR II HITCHES. USE ON CLASS III OR IV ONLY.
2. Trailer loading: Proper trailer loading is your first-line defense against dangerous instability and sway.
Heavy items should be placed on the floor in front of the axle. The load should be balanced side-to-side and
secured to prevent shifting. Tongue weight should be about 10-15 percent of gross trailer weight for most
trailers. Too low a percentage of tongue weight can cause sway. Load the trailer heavier in front.
3. The handle is an on/off device. The bolt below is for adjustment only.
4. When towing during slippery conditions such as wet, icy, or snow-covered roads or on loose gravel, turn
on/off handle counterclockwise until all tension is removed from unit. Failure to do so could prevent tow
vehicle and trailer from turning properly.
5. Do not speed up if sway occurs. Sway increases with speed. Do not continue to operate a swaying vehicle.
Check trailer loading, sway control adjustment and all other equipment until the cause of sway has been
determined and corrected.
6. Never paint or lubricate slide bar.
HOOK-UP
a. Lubricate both balls with a small amount of grease, place socket of slide bar over ball and secure with
clip. Loosen handle until the slide bar can be moved. Extend sway control assembly and place
socket over ball on trailer, secure with other clip.
b. Retighten handle until it stops (handle should be in its original level position). The sway control assembly is
preset at the factory with a tension suitable for most light trailers.
c. On some installations, damage to the sway control may occur during extremely sharp turning maneuvers.
This can be checked by slowly backing vehicle into a jackknife position while someone is watching. Do not
allow slide bar to contract completely (bottom out) or bumper to contact sway control. If it looks as thought
contact will be made or the sway control will bottom out then the sway control must be removed before
backing trailer.
ADJUSTMENT
a. Trailer configurations and loading, road and weather conditions, towing speed, tire condition and pressure,
and center of gravity of trailer all affect towing. To get maximum benefits from the sway control assembly, a
series of road tests should be taken with the loaded trailer. During the first road test try the sway control at
the factory preset force. On subsequent trips increase or decrease tension by turning the adjusting bolt in
1/4 turn increments in the direction shown on the label until the desired control is achieved. For large
trailers, it may be necessary to install a second sway control unit.
b. After about 1000 miles of towing, remove the slide bar from the sway control and clean the friction surfaces
with a wire brush. Repeat this cleaning procedure about every 10,000 miles.
Ron and Amy Benhart
Old 09-12-2011, 02:17 PM   #17
Those are the exact instructions that come with the standard Reese/Drawtite friction sway controller.
Notice that removal of the sway controller for backing is only if you must jacknife to the extent that it would bottom the unit or interfere with a bumper or other object. Normal backing maneuvers will not damage a thing.
» Online Users: 591
124 members and 467 guests
2000XLifted, 4Jeeperz, 5Galvs, Adony, alphadog99, Andy R, Bandit114, Barney1, bean, bear17, biken201, bikendan, bobbygee, Borwick, brookside, Browndog, Busman1947, Cafjackracing, Cascade Bob, cdbus, chiro, chof16, comfun1, cyclepuck, DAISY BOYKIN, dashonthedash, dasimser, ddavis662, ddemme, dec1952, deerslayer, Deputyseven, DGrissom, DonG, donn, DSN46, Dukejr, dummin4fun, dunnnc, elind, forthefunofit, FreedomTracker, frfan, gbpacker, GeorgieGirl, Gizzerd, Gman88, Gollum, Happy Vibe, iscotty123, itat, JamesR, jasni, Jeep4Two, JJones, jmswms, JoeR, joess, Joker, jphillips1075, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, kjoh75, LFugate, lmcleister, louincal, lowbubba, Mad4sax, maggiek, mhartzel, mia, micalo, Mr. Legato, mrmurph, MT28rk, mtnguy, NanaKaren, pandkm, pappcam, Pharmofish, Piston, pixleys, plcrph2, PrairieBoy, punkaccountant, pwrplay, Ragin Cajun, Redheaded blue tick, ret2006, rkswyo, rob and lisa, Rogue69, Rsgtivr6, rstewart06, rwzahm, SabreMarv, SabreSam, Sailfish Bret, sbond, shineysideup, SimchaSabre, skippy31405, snowbrid, softwarejoe, southernsky, spike, Steve7575, texashatter, tgarner2000, Titleguy, tmmar, TN_Jeeper, torben, Triguy, viper48, VTX Al, wakamicamper, wayne anthony, whj77372, william.migues, wvfireboss
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
