Old 05-10-2012, 10:22 AM   #11
Triguy's Avatar
Got it. So its not the L-Bracket.
The only thing I can think of is that the dealer installed incorrectly causing it to bend. As mentioned above, when the Link Pates are installed there should be no gaps between the A frame and the upper or lower bolts that hold the link plates onto the camper frame.
Also, If the link plates are tightened too much they will bow. I finger tightened mine when installing to ensure a good fit to the fame and then torqued to 60 ft-lbs (splitting the difference between the recommended 50-70ft-lbs).
Its possible that they overtightened. 50-70ft-lbs isn't hard to reach.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-10-2012, 10:29 AM   #12
Triguy's Avatar
By the way, doesn't your trailer have an A-style coupler?
If so, your link plates should be installed like the picture below. That might also be a problem that needs to be discussed with the dealer.
Of course, yours is currently correct if you have a B-style coupler.
Name:	Capture coupler.JPG
Scott
2012 Shamrock 233S
Old 05-10-2012, 10:59 AM   #13
bob213's Avatar
Progress Mfg. is known for their great customer service. Call them before you go back to the dealer (1-800-478-5578). You might even email them a picture and ask them to take a look. That way you will have "facts", not opinions, before you confront the dealer.
bob213 is online now   Reply With Quote
Old 05-10-2012, 11:06 AM   #14
Herk7769's Avatar
Yes, that is my point. The single hole in the clamp must rest on top of the frame; the frame height adjustment holes go on the bottom.
HAM CALLSIGN - KC3FFW
Old 05-10-2012, 11:08 AM   #15
Herk7769's Avatar
Could not agree more. This one is worth the phone call/email because the dealer will be buying you some hitch parts.
Old 05-10-2012, 11:09 AM   #16
jaxfl's Avatar
2 things I see.
1 - the bolts connecting the L bracket are between the frame plate and the trame, making my #2 comment.
2 - with the bolts were they are it would cause a pivot point and the downward pressure on the L braket could cause the bending.
I don't think the frame brakets are long enough for the frame on your TT. This means improper installation.
jaxfl is offline   Reply With Quote
Old 05-10-2012, 11:17 AM   #17
Herk7769's Avatar
This is my opinion as well based on the installation manual. The L-Brackets are supposed to "hang" from the top of the frame and thereby be supported by the frame sides. With the clamps upside down, the L-bracket can exert bending force on the clamp.
Using the last bolt hole on the clamp is not the problem; where the L-Bracket is attached to the clamp is...
Old 05-11-2012, 04:11 PM   #18
Just out of curiosity, do you know why the difference in assembly based on what style coupler? I'm having a problem getting enough weight distribution (front too high). I can't remember what type of coupler I have, but it's installed as if I have style B. I was going to raise the L bracket up a hole but couldn't. If the assembly was flipped, I would have leeway to do that.
sellis1053 is offline   Reply With Quote
Old 05-11-2012, 06:04 PM   #19
Herk7769's Avatar
According to the manual, if you have a "B" type coupler (couple low on the frame) or a "V" nose trailer, in order to keep the arms level with the frame member, you need to invert the frame clamps. It is an unusual coupler installation; and I forgot that arrangement is correct in certain situations.
Trudinator, a photo of the coupler would help clear this up.
Old 05-11-2012, 06:32 PM   #20
Thanks,
If that's the only reason, do you see any problem with trying it to give me the ability to raise my L brackets?
equalizer, led pad
