Old 10-18-2010, 07:38 AM   #1
Equalizer brand hitch and air bags
I have both, and new to towing a TT. Wondering if I should pump up the bags first, to supply an air reserve to the bags, the adjust the equalizer branded hitch with those measurements, or the reverse?
wayne1 is offline   Reply With Quote
Old 10-18-2010, 07:43 AM   #2
MtnGuy's Avatar
I think I would get the WDH setup correctly 1st. Make sure you are getting enough weight back on the front end of your tow vehicle. If setup properly, there should be little sag in the rear of your TV.
Airbags do nothing to get the weight back on the front end of a TV. You can have the back end of your TV looking like a 70s muscle car, but you will still have a light front axle, and a rear axle that might be over the maximum RAWR,
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
Old 10-18-2010, 07:47 AM   #3
Head Rambler
Mtnguy is correct. Set your hitch up first and you may find that you don't need the airbags.
In vehicles with auto-leveling systems it's always recommended to disable the system before adjusting a WDH. Same holds true for airbag systems.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
air bags, equalizer
