Old 12-14-2018, 08:45 PM   #1
Equalizer hitch
Pulling a 34 foot toy hauler travel trailer with a 1 ton dual wheel without an equalizer hitch. Anyone done that?
twosocks is offline   Reply With Quote
Old 12-15-2018, 01:04 AM   #2
bikendan's Avatar
Are you asking about the actual 4 point Equal-i-zer WDH or are you using the term "equalizer" for any WDH?
Because the Equal-i-zer has integrated sway control, in addition to weight distribution.
Equalizer WDH
Old 12-15-2018, 09:29 AM   #3
I had a 34 foot toy hauler travel trailer that came with the Equalizer brand anti sway and WD set up and always had some sway issues. Worked ok but after getting my Hensley I will not go back. Locked it in even in high side winds in OK and KS.
I think the trailer mags need to design better for weight loading. Most cargo weight in back past axles and can cause more sway.
Hensley a little expensive but safer and much more enjoyable to drive with it.
2019 XLR Boost 37TSX13 ToyHauler
jricherson is offline   Reply With Quote
Old 12-16-2018, 07:33 PM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Yep had a one ton dully thought I could tow with out the WDH boy big surprise as tt did not handle well at all. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 12-16-2018, 08:07 PM   #5
Unless you are pulling a little toy trailer you should really use a quality weight distribution your hitch.
While on your one ton the back of your TV may not sag much, your trailer will pull weight of of your front end.
MtBiker is offline   Reply With Quote
equalizer, hitch
