Old 05-31-2015, 06:02 PM   #11
Originally Posted by wnelsonfl View Post
These are available thru Amazon. Seem to help with the squeaks and installation of the balls.
wnelsonfl: OK, you're going to have to give me some more info on these. What are they, where do they go, what do they do? Do you have the link to Amazon for them? I can't imagine anywhere on my Equalizer that they will fit. And what do you mean by "installation of the balls?" I've only got one ball (on my trailer at least!).
2011 Traverse LT, 3.6L, FWD
Old 05-31-2015, 07:13 PM   #12
The pads slip over the "L" arms that support the bars. They eliminate the clanking and screeching sounds coming from the hitch and are worth it. I think your problem is that you are not raising your jack high enough to remove the tension off the bars. You may have to use a large block under the jack in order to get sufficient height to raise the jack high enough to release the bars. On my set-up, it actually requires lifting the tow vehicle a little in order to get the height needed to uninstall the bars.
magpi26 is offline   Reply With Quote
Old 05-31-2015, 07:21 PM   #13
Jimandchris's Avatar
These are the Equalizer "bracket jackets" that help with reducing the noise. Fits over the L bracket as shown.
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 05-31-2015, 07:22 PM   #14
Sorry magpi26, didn't see your post.
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 05-31-2015, 08:52 PM   #15
Thanks for the info on the bracket jackets.
Old 06-01-2015, 06:59 AM   #16
Fluffywhitedogs's Avatar
Oh I need those! I usually get home from weekend trips later in the evening and it's embarrassing, clunking and groaning into my quiet neighborhood! This is my first time with WD and I had no idea it was so loud!
Fluffywhitedogs is offline   Reply With Quote
Old 06-01-2015, 07:05 AM   #17
Originally Posted by Brewhedd View Post
Compared to what the dealer provided, which was one of those friction arm jokes, it performs quite well. Towing a Rockwood 2702ss with a 1/2 ton Silverado. While not eliminating all movement it does a good job. Turns towing from tense to relaxed, well worth the 480 bucks.
Gee, I must be doing something wrong. I am on my 3rd trailer using "one of those friction arm jokes" and have had no issues with any of them.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 06-01-2015, 07:31 AM   #18
vinmaker's Avatar
I find my Equalizer hitch does everything it is designed to do. I too feel that it makes the towing experience so much more relaxing. The joint between the trailer and TV is much more solid and eliminates all that bouncing around.
I am a big fan.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-01-2015, 08:14 AM   #19
If it works for you that's great. In my case, it didn't, as a passing truck induced too much sway.
Brewhedd is offline   Reply With Quote
Old 06-01-2015, 08:15 AM   #20
Originally Posted by oldtool2 View Post
You are talking about two different things. The friction arms are for anti-swaying. For you were adding sounds like a weight distribution hitch which is a different animal. They serve two different purposes. I would leave the anti-sway in place. On my last trailer I used both and they work well together.
Jim
The Equalizer is a WDH and 4 point anti-sway system.
equalizer, hitch
