Old 05-29-2015, 10:02 PM   #1
Equalizer hitch, 1st tow.
Compared to what the dealer provided, which was one of those friction arm jokes, it performs quite well. Towing a Rockwood 2702ss with a 1/2 ton Silverado. While not eliminating all movement it does a good job. Turns towing from tense to relaxed, well worth the 480 bucks.
Brewhedd is offline   Reply With Quote
Old 05-30-2015, 08:40 AM   #2
Summer2Go
Summer2Go's Avatar
Having trouble with mine. The bars get stuck in the hitch when I go to remove. I jack everything up to relieve the tension, but the new bars get stuck in the hitch and won't come out. Do I need silicone or something?
Summer2Go is offline   Reply With Quote
Old 05-30-2015, 11:13 AM   #3
Jack it higher.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-30-2015, 01:54 PM   #4
Or don't jack it too high before connecting the bars. You should just jack it to level. I know everyone wants to go another inch to take all the sag out but it's not needed.
Maxhise is offline   Reply With Quote
Old 05-31-2015, 07:36 AM   #5
mjones12's Avatar
I vote for jacking higher. Sometimes my truck must come up very high before bars will go off or on . Depends on where I'm parked.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 05-31-2015, 10:07 AM   #6
I think you need to jack up a little more to relieve the tension or the socket bolts are over torqued. Try loosening the socket bolts and torquing to 45 ft-lbs after checking your manual for the spec. The friction areas are supposed to be lubed.
Old 05-31-2015, 11:35 AM   #7
wbdavey's Avatar
Brew, it's not clear from your description that you're following the correct sequence. First run your jack up to take tension off the bars, then remove the "L" shaped clips and swing the bars away from the trailer tongue and towards the truck bumper. Then remove the pin clips and pins at the hitch head - your bars should slide right out.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 05-31-2015, 12:51 PM   #8
wnelsonfl's Avatar
These are available thru Amazon. Seem to help with the squeaks and installation of the balls.
Warren
2014 Silverado Z71 4x4- 5.3
Flagstaff 21 FRBS
235 nights camping this past 30 months
31000 miles
wnelsonfl is online now   Reply With Quote
Old 05-31-2015, 02:19 PM   #9
You are talking about two different things. The friction arms are for anti-swaying. For you were adding sounds like a weight distribution hitch which is a different animal. They serve two different purposes. I would leave the anti-sway in place. On my last trailer I used both and they work well together.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 05-31-2015, 05:47 PM   #10
wbdavey's Avatar
Right message, wrong guy
[QUOTE=wbdavey;879259]Brew, it's not clear from your description that you're following the correct sequence. First run your jack up to take tension off the bars, then remove the "L" shaped clips and swing the bars away from the trailer tongue and towards the truck bumper. Then remove the pin clips and pins at the hitch head - your bars should slide right out.[/QUOTE
Summer - this post was intended for your problem of not being able to remove the bars from the socket. I inadvertently directed it to Brew, the OP.
equalizer, hitch
