Old 07-20-2012, 09:44 AM   #1
Cool Equalizer hitch
We have a 2010 F150 & 1995 Alju 2210. It tows nicely but I think I should invest in an equalizer hitch. My question is what's involved in installing one? It seems like it should be pretty simple if the directions are used. Camping World wants $200.00 to install one. If I'm missing something please advise. Thanks
BigB10774 is offline   Reply With Quote
Old 07-20-2012, 10:23 AM   #2
sherdep's Avatar
the manual is pretty straight forward
basic tools and if you know how to read a tape measure.
you can also call equilizer for support
the main issue you may run into is tourqueing the ball on the head because it takes a special socket which you can buy from equilizer like I did
and the height adjustment of the hitch head on the shank.
I had to get a longer drop shank to get the heights I wanted it to be at.
if you are installing at camping world and bring it home - you will most likely have to make adjustments to the hitch after you get it loaded as if you were taking it camping so keep that in mind as well
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-20-2012, 10:49 AM   #3
Dave_Monica's Avatar
What the length, tongue weight and total loaded weight of the camper?
Dave
Old 07-20-2012, 08:34 PM   #4
Just replaced my Ez-Lift with one and WOW what a difference. Very easy to install took about 30 minutes. The instructions are fool proof. You will have to make adjustments once loaded and towed for the first time, then just bring it by your local repair shop and have them torque the hitch head and ball.
Is it time to go camping yet?
2012 Wildwood X-Lite 281QB
2011 Ford F150 XLT 5.0L 3.73
bayouboys is offline   Reply With Quote
Old 07-23-2012, 08:14 AM   #5
I have the E2 hitch and had the Equalizer. They are both great. The E2 is cheaper and very easy to install. You'll never tow without one again, it makes a huge difference.
2013 Surveyor 235 RKS
2010 GMC Savana AWD 5.3L
Mr. Vic is offline   Reply With Quote
Old 07-23-2012, 08:26 AM   #6
MtnGuy's Avatar
Many campers put the entire line of WDHs into "equalizer" hitch. Equal-i-zer is a name brand and seems to be a great hitch. There are other WDHs with integrated sway control, such as Blue Ox Sway Pro, Reese Dual Cam, and a some other makes. Do the research on here or on the net before making the purchase. If indeed Camping World is going to install and Equal-i-zer, then all is good. But they also carry another brand that does not have integrated sway control. Just make sure you know what you are getting.
Old 07-23-2012, 08:32 AM   #7
I had the Equal-i-zer, it's about $500. A good system.
Old 07-30-2012, 04:26 PM   #8
If you can read instructions and use tools it is easy to set up. Just takes time and patience. Follow the torque recommendations closely especially the bolts that hold the sockets for the spring arms on the hitch.
pwrstroke2012 is offline   Reply With Quote
Old 07-30-2012, 04:35 PM   #9
biggest problem is having the right torque wrench...if you have one great...otherwise one of the previous posters has a good idea about getting one torqued by someone else. I love my Equalizer....make sure you get the better 4point sway and not the 2 way.....
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 08-03-2012, 10:21 PM   #10
Red face So about these WDH's
I have the E2 hitch and purchased it due to sway encountered on our first trip. While I no longer experience any sway I was wondering if upgrading to an Equalizer hitch might reduce or eliminate the "washboard effect" felt on some highways? I've been told this is not avoidable and is just a characteristic of some highways. Is it sound advice or are there other alternatives such as varying the cargo location?
Thanks in advance for your experience.
chuckmedic is offline   Reply With Quote
equalizer
