Old 11-19-2014, 11:00 AM   #1
BlakeB's Avatar
Equalizer hitch and new Ram 2500 6.4L
Just a quick question... I had a 2014 5.0L F150 that I was pulling my TT with and decided to upgrade to a 2014 Ram 2500 Big Horn 6.4L. Problem is...the hitch on the Ram sits 5" higher than the one on my F150. Am I going to need to purchase a longer shank than my Equalizer came with to make up for the height difference?
Top of my receiver is 25 1/2" off the ground on the Ram. I believe the old one was 21". I still have the bottom 2 holes (see photo) in the current shank but not sure if that will make up 4 1/2".
My TT is in storage for the winter but just trying to get this straightened out over the winter.
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 11-19-2014, 11:13 AM   #2
AKA: 'tiredTeacher
awellis3's Avatar
Remove the hitch head, turn the shaft over and reinstall the head. They work in either direction. Then all the empty holes will be on top giving you more drop.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 11-19-2014, 11:26 AM   #3
BlakeB's Avatar
Won't putting the hole on top only allow for me to make it higher?
Old 11-19-2014, 12:12 PM   #4
fx2
I went from a 2012 F150 SCrew FX2 to a 2014 Ram 2500. I dropped to the lowest 2 holes and it is perfect, sits level and rides great. I don't have all of my measurements with me so I can't say exactly what they were.
fx2 is offline   Reply With Quote
Old 11-19-2014, 01:51 PM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Yes, I have no idea what I was thinking. If moving the head down to the last two bolt holes won't level the trailer, a new shank is in your future.
Wright and Penny
Richmond, Va.
Old 12-06-2014, 01:39 PM   #6
gashog's Avatar
When I went from a Ford F-150 to a 2014 Ram 2500 Laramie Longhorn 4x4, I had the same problem, new truck was taller. My Weight Distribution Hitch is a Husky. I just changed out the Shank and I also went with a Class 5 (2.5 inch shaft) where I wouldn't have to use the 2.5 inch to 2.0 inch bushing. I looked everywhere and could only find a Class 5 (2.5 inch) shank on ebay. Here's what I got it it worked great. just make sure you torque the bolts to the spec, my required 260 ft. lbs.
5 5 8" Deep Drop 2 5" Shank Weight Distribution Hitch | eBay
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 12-12-2014, 06:33 PM   #7
BlakeB's Avatar
Thank you! I was actually thinking about doing a 2 1/2" shank too so it wouldnt "clang" around with the adapter. I have a few months before it gets warm enough to camp so I'll check around on ebay
Old 12-14-2014, 08:34 AM   #8
Dodge Guy's Avatar
Just measure from the center of the bottom bolt head on the head to the center of the bottom bolt hole in the shank. It looks to be around 4 ". you should be all set.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
500, equalizer, hitch
