EQUALIZER Hitch - does it work for WD?
I’m just wondering what to expect from this hitch and whether it actually works for WD. In the EQUALIZER installation manual the following describes a “Good Setup”:
Good adjustment:
You have most likely achieved good weight distribution adjustment if your measurements show the following with the trailer coupled and the weight distribution engaged:
1. From the coupled without weight distribution measurement, the front wheel well measurement is at least halfway back to the original uncoupled measurement.
Am I all wrong or does the above measurement mean I haven’t even returned all of the load transferred to the rear axle back to the front end, let alone distributing any tongue weight to the front end. For those that have this hitch is this the best you can do with this hitch? Or when you take your final measurements is the front end with WD less than your uncoupled measurement? Has anyone gone to the scale and been happy?
Thanks for your help.
F150, ECO, Max tow, & soon MICRO 25 KS
