Old 04-11-2016, 09:37 PM   #21
Too Tall's Avatar
Originally Posted by SeaDog View Post
I just finished setting up my WDH, the set bolt according to the instructions should be tightened until the rivet washers touch and then tighten another 1/4 turn. and should be checked after 50 miles of towing, large bolts holding head torque to 260 LBS
70 ft/lbs torque seems high? I was under the impression that the set bolt just keeps the washers tight till you torque down the two 5/8'bolts.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-15-2016, 09:04 AM   #22
thebrakeman's Avatar
If you tightened that set bolt before engaging the WD bars, that's the problem. Engaging the system will pulls up on the head with tremendous force.
When making adjustments, tighten that bolt to contact, just do it doesn't move while you work. Then after engaging the bars, tighten to contact, plus the 1/4-turn.
thebrakeman is offline   Reply With Quote
Old 06-24-2016, 10:02 AM   #23
RiderBloke
RiderBloke's Avatar
Folks , my hitch has done 5,500 miles and I need to tighten it and the ball. The cost of the tools to do all this is high. Is it better just to have a regular checkup and tighten by a workshop or do most buy the tools and DIY?
Also where do you buy the muscle to put such huge torque forces on the hitch ball etc?
Sent from my iPhone somewhere on the face of the earth using Forest River Forums
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
Old 06-24-2016, 11:06 AM   #24
450 on my ball. Bought a 40 inch breaker bar and put all of my 150 lbs weight a few inches from the end of it. That is 450. My dealer installed my hitch and the ball was loose after the 30 mile drive home. Made no sense to bring it back (they obviously didn't know what they doing anyway) so I bought the tools to do it myself. Had to redo the hitch as well.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-24-2016, 12:07 PM   #25
When I installed mine I took it to a local truck shop who tightened it for $20. They used the big impact driver they use on the big trucks and it is still as tight as the day I had it done.
keith_h is offline   Reply With Quote
Old 06-24-2016, 12:46 PM   #26
Folks...
Proper torque is important. 450 ft/lbs seems like a lot, however with a big (long) breaker bar it is easy to over-torque.
Just use math. For a 150 lb person to torque 450 ft/lbs, you need to put all your weight exactly 3 feet away from the center of the bolt/nut. Just divide the needed torque by the weight you have.
No jumping or bouncing, just slowly place all your weight at the calculated distance on the bar... with the bar parallel to the ground.
I'll use myself as an example: I weigh 175 lbs. To torque 450 ft/lbs, I need to be 2.57 feet from the center line. That is basically 2'-6".
lbrjet has it right. 150 lbs, a few inches from the end of his 40 inch breaker bar (36" territory) is 450 ft/lbs.
325BH is offline   Reply With Quote
Old 06-24-2016, 12:51 PM   #27
I should add: There is so much riding on that one bolt/nut (the ball), you don't want to screw it up.
Also, pay close attention to the lock nut. If it spreads apart due to nut grabbing and twisting it, it can get squeezed out during use. That would be bad. (I am in the camp of "lock nuts are stupid". I torque without them and use lock-tite. But that is for another discussion.)
Old 06-24-2016, 02:34 PM   #28
RiderBloke
RiderBloke's Avatar
Thanks to all the respondents so far. I'm thinking about what to do. I have the luxury of time as mine is mainly a winter traveler.
Sent from my iPad using Tapatalk
Old 06-24-2016, 02:49 PM   #29
Thank' s Guys
I'm new to all this and I greatly appreciate this information..
crossfireshots is offline   Reply With Quote
Old 06-24-2016, 04:13 PM   #30
RiderBloke
RiderBloke's Avatar
Another 2 questions for the mechanics: What do you use to hold the ball still when you are applying such torque? Do you put the hitch in the receiver sideways to do up the nut? (I don't think my wife could hold it still on the floor while I lean on it. )
equalizer, hitch
