Old 09-02-2013, 12:28 PM   #1
Roger and Paula
Equalizer hitch recommendation
Ok. So I'm getting a Salem 28' LE. Last RV was a motor home, and hitches have changed since my last TT. So, looking at a Reese roundbar equalizer with sway control vs an Andersen hitch. Totally different systems, but the Andersen looks a lot easier to hook up and operate vs the Reese. I am open to suggestions from everyone.
Rstrahan is offline   Reply With Quote
Old 09-02-2013, 02:02 PM   #2
Canadian Member
itat's Avatar
Do a quick search on this forum and you'll find a lot of great info on WD hitch and sway control products. The most popular products seem to be the Reese Strait-Line with dual cam sway control and the Equal-i-zer brand. There are several others. I have the Equal-i-zer. It works well. It's easy to setup and remove, but can be noisy. I'm not familiar with the Andersen hitch.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 09-02-2013, 02:53 PM   #3
bikendan's Avatar
using the term "equalizer" to talk about WDH's is confusing, since there's only one Equal-i-zer WDH and it's a registered brand name.
kind of like using the term "kleenex" for any brand of tissue paper.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-04-2013, 10:42 AM   #4
Stg1's Avatar
Actually, Weight Distribution hitches are equalizers. They equalize the weight of the tongue between the front wheels of the tow vehicle and rear wheels of the trailer.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 09-04-2013, 10:52 AM   #5
Triguy's Avatar
I haven't used an Andersen but the design and benefits are intriguing. I would consider it if I were buying new. But, I also tend to like the old tried and true and the Equal-i-zer 4-point and Reese Dual Cam are hard to beat.
Here are a couple of threads on the Andersen...
Andersen Weight distribution hitch
Andersen hitch, Wow!!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-04-2013, 04:37 PM   #6
thebrakeman's Avatar
Fine. But the fact is that when you say "Equalizer" around here, most will think you are talking about the specific "Equal-i-zer" brand sway control hitch. Best to refer to the generic system as "WDH" to avoid confusion.
thebrakeman is offline   Reply With Quote
Old 09-04-2013, 04:42 PM   #7
If your goal is to simply level the rig a bit, and not have any noise, go ahead and try the Anderson. But if your goal is to transfer all lost weight back onto the front wheels, then the Anderson will likely disappoint, due to the method of load application. If your truck is well over-spec'ed for the trailer, however, the Anderson would be fine.
Tried and true, best bang-for-the-buck around here, are the Reese Dual-Cam setup, or the Equal-i-zer 4pt Sway Control hitch.
Old 09-04-2013, 05:25 PM   #8
Mister's Avatar
I also have a 4 pt "Equalizer" and love it. Both in terms of weight distribution and sway control I love it. I'm using a 12K model paired up with my ~10K GVWR 36' TT and they work well together.
Grease the joints on the hitch head where they contact the bottom side of the ball plate or it will creek like crazy with every sharp turn. It will sometimes anyway. I take steel wool to my L-bars on the trailer tongue at the beginning of the season. I should probably store them indoors. Once you get it dialed in for the right ball height, pivot angle, and L-bracket height...it's a great setup.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
equalizer, hitch
