Old 03-06-2016, 02:44 PM   #11
I learned my lesson having the dealership doing it. Lol. Was way off. I was just a little concerned with the bars not being parallel. They are a little upward pitched roughly an inch.
Appreciate all of the input
Marty, Carla, Gabby and our ankle biter Rocky
Dodge Ram 1500 SLT Big Horn 4x4 Hemi 5.7
Forest River Wildwood 30KQBSS
eyeguy1 is offline   Reply With Quote
Old 03-06-2016, 03:28 PM   #12
Canadian Member
itat's Avatar
Equal-i-zer's setup instructions are pretty easy to follow. I had the same experience with my dealer's setup. I had to change the number of washers and lower the L brackets to get mine setup properly and have the bars parallel to the A-frame. They need to be parallel to the A-frame in order to sit flat on the L bracket surface and provide max. friction (i.e. sway control). On the 3rd adjustment I had it right.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 03-06-2016, 03:31 PM   #13
Equalizer Hitch trunnion bar set up
Yes, if you lower the L bracket one notch adding one washer should keep the weight distribution nearly the same.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-06-2016, 03:42 PM   #14
Thanks guys. I thought my logic was correct. It there is an upward pitch then the trunnion bars are not getting maximum coverage on the l bracket. I am gonna try lowering brackets one hole and add one washer and see how that looks and performs
Again thanks for the input. Having more input provides for a better decision on what to do
Old 03-06-2016, 05:31 PM   #15
Originally Posted by SA3056 View Post
Your gonna have some bend or angle on the bars, that's kinda the point. If your tv and trailer are level when hitched and it drives good then I would leave it. I have tried adding washers and lowering brackets but always go back to the original set up (following the manual to set it up) evereytime because I feel better behind the wheel and that's the true test.
Totally Agree. I wouldn't touch it!
gfarmcafe is offline   Reply With Quote
Old 03-06-2016, 05:45 PM   #16
Canadian Member
itat's Avatar
SA3056 and gfarmcafe, the OP has an Equal-i-zer brand WDH. The bars do not bend like on WDHs with chains.
Old 03-06-2016, 07:31 PM   #17
SA3056's Avatar
Ive changed ours several times and have always witnessed some degree of bend honestly I'd be concerned if there wasn't. The bars are part of the WD not just for the sway control. But no one knows better than the man behind the wheel.
SA3056 is offline   Reply With Quote
Old 03-06-2016, 07:35 PM   #18
I guess my biggest concern is the upward slant of the trunnion bars since they are suppose to be parallel. I plan to lower the L Bracket one hole in the morning and add one spacer and go for test run.
If I can improve the handling a little more by tweaking it a bit I will be happier than a pig in s&!+ 😎
Old 03-07-2016, 10:43 AM   #19
I had an issue with not enough weight transfer (1k/10k EQ) so raised the L brackets one hole. Got back to front wheel-well clearance same as unhitched but had "non-parallel" bars. Added 1 washer and lowered the L brackets back the 1 hole and maintained the proper wheel-well clearance. You will be fine and the hitch will be quieter.
DRiveWell is offline   Reply With Quote
Old 03-07-2016, 10:58 AM   #20
Also if you can "Manually"place the Bars on the L brackets,there will be Little/No sway control! Youroo!!
youroo is online now   Reply With Quote
equalizer, hitch
