Old 03-07-2016, 11:19 AM   #21
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by doc73 View Post
Can't help with adjustment, but my 4 Point needs the trailer raised up several inches and it still "pops" into place using the cheater bar....
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 25
Old 03-07-2016, 11:52 AM   #22
(Dry Huunday)
DreiHunde's Avatar
While the goal is that the bars be level with the frame during the initial set-up, the manual does say you can move the L-Brackets to correct under adjustment or when there are changes to "vehicle loading". Page 20.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 03-07-2016, 12:14 PM   #23
Canadian Member
itat's Avatar
Both the TV and the trailer should be fully loaded for camping when you do your setup to correct the dealer's attempt. As I said earlier, I had to adjust mine 3 times before I got it as close to perfect as I could.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 03-07-2016, 01:23 PM   #24
Ok folks. Spent all morning adjusting and test driving.
With nothing hooked up
Front. 37.5 inches
Rear. 41 inches
Hooked up with no trunnion bars
Front 38.25
Rear. 38.25
Hooked up with trunnion bars
Front 37.5
Rear 39.5
And the trunnion bars are parallel to the tongue now.
I think I have hit the adjustment on the nose? I think??? Lol
Lowered L Bracket one hole and added two spacers.
Let me know what you guys think of the numbers above? By the manual, if I am reading it correctly, I have achieved proper wd since my front measurement is identical hooked up with wd or not hooked up at all??
Marty, Carla, Gabby and our ankle biter Rocky
Dodge Ram 1500 SLT Big Horn 4x4 Hemi 5.7
Forest River Wildwood 30KQBSS
eyeguy1 is offline   Reply With Quote
Old 03-07-2016, 03:20 PM   #25
(Dry Huunday)
DreiHunde's Avatar
You definitely moved wt back to the front, how's it tow? To me that's the key in telling you if you got it setup right!
Beau & Sue
FurKid Express
Old 03-07-2016, 03:26 PM   #26
Today we had about 20mph winds and it towed pretty straight until about 55mph then the wind would push it a little. That is a pretty good wind. I am hopeful that on a calmer day she will pull straight about 65mph. We will see but I think it did pretty well given the strong winds today
Old 03-07-2016, 04:51 PM   #27
(Dry Huunday)
DreiHunde's Avatar
Beau & Sue
FurKid Express
Old 03-08-2016, 07:34 AM   #28
20 MPH winds are Not "Strong Winds" Gusts from out of Nowhere when you are going 65 or 55 MPH Really makes People Quit "Texting and Talking on the Phone"! Youroo!!
youroo is online now   Reply With Quote
Old 03-08-2016, 08:16 AM   #29
Very true Yooroo. Actually while watching the weather last night they said we had 30-35mph and calming to 20mph today. Lol. I may have to do a little tweaking still but am gonna wait until a test drive on a calmer day
Old 03-09-2016, 02:00 PM   #30
thebrakeman's Avatar
I have to disagree with the idea that some angle to the bars is OK. if you can visibly see that they are not parallel to the A-frame, you will have a wear problem on the bars.
The bars are supposed to ride parallel on the surface of the L-bracket. That is to maximize the surface contact. If the bar is noticeably angled upward toward the L-bracket, then there will only be line-contact (at the front edge of the L-bracket), rather than surface contact. This will cause that leading edge of the L-bracket to dig into the bar(s) during turning, increasing noise and wear. Sway control likely will not be affected, but you will be damaging the bars.
I like your plan of lowering the L-bracket, and adding 1 washer to the head. If the weight-transfer is spot on now, lowering the L-bracket will decrease weight transfer, so you will need to compensate with some number of washers. Might as well start with 1.
thebrakeman is offline   Reply With Quote
equalizer, hitch
