Old 10-28-2012, 03:18 PM   #11
Originally Posted by pwrstroke2012 View Post
yes. arms should swing freely.There will be some resistance though. they should be torqued at 45# I believe, look at manual.
Thank you. The factory default, even superman can't move it
tntrac is offline   Reply With Quote
Old 10-28-2012, 09:33 PM   #12
Finally got the installation done. Using 6 washers worked for me. Also, the shank, I had reverse it (Equalizer web site suggest the shank down). With the shank being down, I scraped the driveway so I didn't want to take a chance like last night.
I didn't drive the freeway to test it out but did only the local street.
Since the ball is tilted, does that reduce the effectiveness of the locking mechanism to lock in the ball? Just being paranoid I guess.
Old 10-29-2012, 07:34 AM   #13
lindy's Avatar
No 6 washers is fine that's what I've had on mine for 2 years now.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-29-2012, 08:10 AM   #14
X2...no worries! You should lube and re-torque (per manufacturer recommendations) your link plate bolts every year.
pwrstroke2012 is offline   Reply With Quote
Old 10-29-2012, 08:16 AM   #15
Road-King's Avatar
There is a video on youtube showing the setup process. They said in that video to start with 5 washers, then add or subtract as needed. So 6 should be no problem at all.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 10-29-2012, 12:08 PM   #16
8 washers is the max. Loosen the hitch head socket bolts and lube the top and bottom areas around the sockets and swing the sockets back and forth with a bar to distribute the lube. I tighten mine to 60 and that works well for me. The sockets are the main sway control so it is important to adjust these correctly.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-29-2012, 02:31 PM   #17
lindy's Avatar
I'm not sure of the 8 washers, I've heard people having trouble uncoupling because of the ball angle while using 7 washers. Might just have been an issue with the trl tongue too.
F.R.O.G. member
Old 10-29-2012, 04:08 PM   #18
8 washers is taken directly from the installation manual.
Old 10-29-2012, 07:13 PM   #19
wyo700's Avatar
I have seven washers in mine and has never had a problem with coupling or uncoupling. When the bars are attached it almost brings hitch head back to straight up. I need to transfer a little more weight and will be putting the 8th washer in next year to try it out.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 10-31-2012, 03:20 PM   #20
thebrakeman's Avatar
Originally Posted by Triguy View Post
One more thing. I said above that Toyota has their own recommendation. Specifically, I think the manual says to adjust the weight distribution hitch until front fender is returned to the same height as before connection.
But please check your Toyota manual to confirm.
Exactly. The main goal of any WDH kit should be to return every bit of lost weight back to the front axle. The rear measurements are only a check to be sure you didn't actually increase the rear beyond stock.
You need to shift more weight, by adding more washers. If you are already level, then you may need to drop the head on the shank to the next slot. But try the washers first. If less than 1" tongue-high, that's OK.
thebrakeman is offline   Reply With Quote
equalizer
