05-16-2011, 02:40 PM
Equalizer Question - Which one.
I am going with an Equalizer 4 point 1000-10,000 which will work fine, but is it a big deal to go with a 1200-12000. The cost difference isn't much.
Do they weigh more? Is it noticable? Any problems with going with a larger hitch?
thanks in advance.
05-16-2011, 02:48 PM
Moderator
What is the trailer weight and the tongue weight of your trailer?
Scott
DW, DD's x 3 and Murphy the Camping Dog - A Golden
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD, P3, Equal-i-zer
05-16-2011, 03:35 PM
Trailer and Truck Specs
Model 29BHS
 Dry Hitch Weight920 lb. (417 kg )Dry Ship Weight6,485 lb. (2,942 kg )GVWR7,920 lb. (3,592 kg )Cargo Carrying Capacity1,376 lb. (624 kg )Exterior Length32 ft. 5 in. (9.9 m)Exterior Height10 ft. 9 in. (3.3 m)Exterior Width96 in. (2.4 m)Fresh Water Capacity43 gal. (163 L)Gray Water Capacity37 gal. (140 L)Black Water Capacity37 gal. (140 L)Awning Size19 ft. (5.8 m)
The trailer is a 2012 Wildcat 29BHS (Easy Specs are below)
http://www.forestriverinc.com/nd/def...ries=TTrailers
The truck is a 2008 Toyota Tundra CrewMax with the Towpackage.
I am thinking of getting the Prodigy P2 break controller as well. Is it worth it?
Thanks again for any info.
05-16-2011, 03:36 PM
Model 29BHS
05-16-2011, 08:41 PM
Moderator
1200/12000 bars would work for you better than the 1,000/10,000 IMO.
Your tongue weight is going to be really close to being over 1,000lbs. I think you will find that it will be relatively easy to load enough in this TT to get close to its GVWR of 8,000lbs. A modest tongue weight percentage of 13% would be 1,040lbs. 15% would put you at 1,200.
The prodigy P2 is a good choice. The P3 can be found for about $20 more but there is no difference in their braking performance.
By the way - welcome to the forum. I really like that floorplan and hope you have some great camping.
Scott
2012 Shamrock 233S
05-16-2011, 09:40 PM
The Prodigy P2 or P3 is an excellent choice.
2010 Flagstaff 25 DS
2004 Dodge 2500 Hemi
05-16-2011, 10:14 PM
Thanks very much.
Thanks for the quick reply. I ordered the 1200/12000 equalizer today. Thanks for the great advice. I got the P2 as well. We like the floorplan too. If the two young kids get out of control we can lock them in the back. JK Hopefully we get to pick it up at the factory this weekend.
Thanks again for the quick reply.
05-16-2011, 10:18 PM
Ordered it. Thanks
05-17-2011, 01:08 PM
Good choices on both counts. Really borderline on with the 1000 lbs WDH. Prodigy is the best.
PS - Per the Equal-i-zer site, the 1200 lbs unit is 107 lbs versus 100 lbs for the 1000 lbs version.
Head is 1 lb heaver, and each spring bar is 3 lbs heavier.
2004 Surveyor SV261T UltraLite Hybrid
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 586 |
| 122 members and 464 guests |
| 2000XLifted, 4Jeeperz, 5Galvs, Adony, alphadog99, Andy R, Bandit114, Barney1, bean, bear17, biken201, bikendan, bobbygee, Borwick, brookside, Browndog, Busman1947, Cafjackracing, Cascade Bob, cdbus, chiro, chof16, comfun1, cyclepuck, DAISY BOYKIN, dashonthedash, dasimser, ddavis662, ddemme, dec1952, deerslayer, Deputyseven, DGrissom, DonG, donn, DSN46, Dukejr, dummin4fun, elind, forthefunofit, FreedomTracker, frfan, gbpacker, GeorgieGirl, Gizzerd, Gman88, Gollum, Happy Vibe, iscotty123, itat, JamesR, jasni, Jeep4Two, JJones, JoeR, joess, Joker, jphillips1075, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, kjoh75, LFugate, lmcleister, louincal, lowbubba, Mad4sax, maggiek, McLuer, mhartzel, mia, micalo, Mr. Legato, mrmurph, MT28rk, mtnguy, NanaKaren, pandkm, pappcam, Pharmofish, pixleys, plcrph2, PrairieBoy, punkaccountant, pwrplay, Ragin Cajun, Redheaded blue tick, ret2006, rkswyo, rob and lisa, Rogue69, Rsgtivr6, rstewart06, rwzahm, SabreMarv, SabreSam, Sailfish Bret, sbond, shineysideup, SimchaSabre, skippy31405, snowbrid, softwarejoe, southernsky, spike, Steve7575, texashatter, tgarner2000, Titleguy, tmmar, TN_Jeeper, torben, Triguy, viper48, VTX Al, wakamicamper, wayne anthony, whj77372, william.migues, wvfireboss |
| Most users ever online was 996, Yesterday at 11:04 AM. |
