Old 06-30-2016, 10:37 AM   #1
Ejs4029's Avatar
Equalizer vs Andersen Hitch Which One ?
I have decided I am going to replace my old hitch setup that uses the friction sway control for either an Equalizer 1200 or Andersen setup. I have no issues with the old setup other than having to use a shank that is too long from a previous tow vehicle and having to remove the sway control when backing up so itís time for a change.
My TV is a 2015 RAM 2500 Diesel and my TT is a Rockwood 2703 that loaded is around 7500lbs tongue weight is listed at 643 so I would guess at max loaded no more than 1000lbs or so which includes stuff I am carrying in the bed behind the rear axle. I am torn between which one to get I like the simplicity of the Andersen with 8Ē drop and itís light weight and relative ease of setup. I like the Equalizer because I can get the 2.5Ē shank with the 6Ē drop down and tried and true design that gets good reviews I know itís heavier and probably alittle tougher to get dialed in.
So I would appreciate any feedback both pros and cons of each setup.
ID:	112674   Click image for larger version
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 06-30-2016, 10:51 AM   #2
You got two choices. One that is proven to work well even has 2.5 inch shank, or one proven to be hit or miss depending on rig. I don't think Andersen has the 2.5 shank. The slop you can have with receiver sleeve is enough that I would want it to be more solid
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 06-30-2016, 09:23 PM   #3
Engineer of Crazy Train
ChooChooMan74's Avatar
Cheapest is to cut the shank. We did that at the race shop. We needed a drop that was just a little more than the next size. We cut off the excess.
Sent from my Samsung Note 4 using Tapatalk.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 06-30-2016, 09:57 PM   #4
KDHfan's Avatar
I have yet to hear anyone say "the Equal-i-zer didn't work out for me." Ive heard quite a few people say the Anderson couldn't transfer enough weight to the front of their TV. So, while the lightweight of the Anderson is appealing, I'll stick with my Equal-i-zer. I've been using it for 4 years on two different campers and two different TV's. Zero complaints.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 07-01-2016, 01:39 PM   #5
CaptnJohn's Avatar
I used an Equalizer for years and never a problem. Would still be using it if I did not have a 5er. I put a receiver lock through the hitch and never took it out. Easy to load/unload the tongue as long as it was high enough.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 07-01-2016, 01:45 PM   #6
equilizer
i have had the equalizer hitch for over 6 years and really like it. I don't get the sway I use to get with my other hitch. I have a Salem 831 SS and it pulls nicely with my Ford Expedition.
jpbrough is offline   Reply With Quote
Old 07-01-2016, 01:51 PM   #7
I must agree Equalizer!
wzpsjm is offline   Reply With Quote
Old 07-01-2016, 01:54 PM   #8
(Dry Huunday)
DreiHunde's Avatar
Im using an equalizer (1200) with a 2 1/2" shank - 8" Drop. Just set it up for the second time for the new truck and it really isnt difficult...just follow their directions, pretty strait forward!
Love the results on both trucks!
yes the hitch head/shank tis a tad heavy, but it is rock solid!!
I bought a Hitchgrip....the thing is well worth the money!!!!
http://m.campingworld.com/shopping/item/hitchgrip.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 07-01-2016, 10:26 PM   #9
Andersen Experience
I've logged about 4300 miles towing a 2015 Wildwood 241QBXL (loaded wt about 5400lbs) with a 2012 F150, 5L, P275/65R18 GY Wrangler tires. I would say I'm near the practical max weight limit for the Andersen in terms of weight transfer. The trailer is fairly well behaved while towing, but well short of perfect. DW will not even try to tow it.
As you can read on this forum the problem of sway is a multi-faceted problem to solve. So without starting a new thread I'll close by saying I installed a Hensley Arrow and the towing experience is so unbelievably good, I would not have believed it without experiencing it myself.
Happy Camping,
Jamnut
Jamnut is offline   Reply With Quote
Old 07-01-2016, 10:35 PM   #10
Blog: RVroadtripper.com
hbillsmith's Avatar
Towed 12000 miles with Andersen. Great experience and I would do it again. Now in a 5th wheel and went with Andersen again.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
equalizer, hitch
