Old 03-09-2016, 06:42 PM   #1
Equalizer with Geny Hitch
I did a mock up of the adapter that I`m in the process of getting these to together. Please note that this is just a mock up of what it will look like. Not for use in anyway shape or form . Click image for larger version
Big Red and 30WR is offline   Reply With Quote
Old 03-09-2016, 06:50 PM   #2
The steel adapter will have a top plate and gussets. A few of you was wondering so I decided to post it now before its done. It should work but if it doesn`t then I`ll use it on my other trailer without WDh .
Old 03-10-2016, 01:54 PM   #3
thebrakeman's Avatar
Why the new thread?
Better to keep this documented in your original.
thebrakeman is offline   Reply With Quote
Old 03-10-2016, 02:07 PM   #4
Originally Posted by Big Red and 30WR View Post
I did a mock up of the adapter that I`m in the process of getting these to together. Please note that this is just a mock up of what it will look like. Not for use in anyway shape or form . Attachment 101491
By the Pic it looks like the Hennsley is on its Side,and a Reese bar type is bolted to it? What is going on here? Youroo!! Is this a "Henresse"!
youroo is online now   Reply With Quote
Old 03-10-2016, 04:06 PM   #5
Originally Posted by thebrakeman View Post
Why the new thread?
I thought it would be documented better if I added both hitch names . I tried looking online for any info about this set up. Nothing came about. Geny said it would work with weight distribution. I recently emailed them about building adapter plates for WD heads. but have since seen no relpy yet. I bought this model because it was shorter. Just the geny alone is 8 inches long from truck receiver . So all together from truck receiver end to center of ball is 15.75 inches. May take alittle bit of time to dial it in but I`ll do my best.
Old 03-10-2016, 04:08 PM   #6
It does look sort of like that doesn`t it. Maybe we can come up with a flashy name for it.
Old 03-11-2016, 01:30 PM   #7
Is this a solution looking for a problem? What are we tryig to fix?
pdqparalegal1 is offline   Reply With Quote
Old 03-11-2016, 04:08 PM   #8
Go to geny hitch.com and start reading, too much to list . Main thing I`m after is to break the shock transfer between truck and trailer and vise versa . Its and hit or miss @ this point.
Old 03-14-2016, 09:41 AM   #9
This was discussed on his initial thread.
I think he has a unique problem that he wants to address, that most people do not experience???
Old 03-14-2016, 11:27 AM   #10
I`m going with the game plan that this maybe a cheaper solution to a air hitch. Read what geny hitch claims it does and thought why not mate it up with my current equalizer hitch. Won`t know until I try it .
equalizer, hitch
