Old 10-09-2015, 05:52 PM   #11
Kenny kustom's Avatar
Originally Posted by SuicideSaints View Post
Hit the search and you will get hundreds of situations such as yours. Unless you have a HD tow and an light weight 5th wheel you are going to be at or over the max.
I have a 28 foot TT thats hitting about a 1300# TW, I run a 2500 diesel. A lot of people said I would be fine with a 1/2 ton because it was a bumper pull but I knew I would have a high TW due to dual 30lb tanks and dual batteries up front. I also load my truck bed up with bikes, toys, and generators. Also I tow mountains all the time so I wanted the power and torque the diesel ?
Dollars to donuts, you are over too....
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 10-09-2015, 06:39 PM   #12
Phat Phrog Stunt Crew
elind's Avatar
12 pack with my popcorn, PLEASE.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 10-09-2015, 06:42 PM   #13
B and B's Avatar
2008 F350 CCSB V10
2016 Sabre 36QBOK
I will raise you a french crueller and walnut log!!
Old 10-09-2015, 06:45 PM   #14
LTnTN's Avatar
My Flagstaff Super Lite 8528RKWS has a pin weight of 1100 and dry weight of 7700. With that I can keep my F150 in good shape.
2015 Flagstaff 8528RKWS
2013 Ford F-150 Ecobeast
LTnTN is offline   Reply With Quote
Old 10-09-2015, 06:45 PM   #15
Total Bliss's Avatar
Originally Posted by phillyg View Post
Here we go, again. Popcorn anyone?
And don't forget the raisinettes
Total Bliss is offline   Reply With Quote
Old 10-09-2015, 06:58 PM   #16
Looking for goobers
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 10-09-2015, 07:00 PM   #17
LTnTN's Avatar
Old 10-10-2015, 09:23 AM   #18
MtnGuy's Avatar
For those just watching, no need to hijack the thread with concession items.
Back to the topic.
Old 10-11-2015, 05:10 PM   #19
OscarsMom2's Avatar
We owned a "1/2 ton towable" fifth wheel when we purchased our 2012 Ford F150 with the eco-boost engine. We were looking to upgrade it and found that the cargo capacity of our pickup was not enough for the pin weight. We traded it in on a smaller travel trailer.
OscarsMom2 is offline   Reply With Quote
Old 10-13-2015, 11:23 AM   #20
Don
I'm in the same boat as I am also a newbie. I have a 2007 Tundra with 5.7L V8 with full factory tow package that is rated to two 10,600 lbs. I purchased a RW Premier Ultralight 5th Wheel that has a gvwr of 9206lb. If I use the suggested 15 and 25% of gvwr as my range for pin weight that is 1381# min pin wt. and 2301 max pin wt. I read this and got to checking and my payload (CCC) for my truck is 1475. After taking out 340# for my wife and me and 250 for hitch in bed that leaves 885 for pin wt. I am way over wt. as I see it. Any disagreement? As a newbie to 5th wheels I naively listened to the salesman convince me that my truck could more than handle the weight and pull the RV with out problems. Do I need a new and bigger truck?
Sandy12345 is offline   Reply With Quote
