Old 10-13-2015, 10:16 PM   #21
amblt's Avatar
Originally Posted by Sandy12345 View Post
I'm in the same boat as I am also a newbie. I have a 2007 Tundra with 5.7L V8 with full factory tow package that is rated to two 10,600 lbs. I purchased a RW Premier Ultralight 5th Wheel that has a gvwr of 9206lb. If I use the suggested 15 and 25% of gvwr as my range for pin weight that is 1381# min pin wt. and 2301 max pin wt. I read this and got to checking and my payload (CCC) for my truck is 1475. After taking out 340# for my wife and me and 250 for hitch in bed that leaves 885 for pin wt. I am way over wt. as I see it. Any disagreement? As a newbie to 5th wheels I naively listened to the salesman convince me that my truck could more than handle the weight and pull the RV with out problems. Do I need a new and bigger truck?
Don't listen to the salesmen, listen to the members on this blog- the majority are bang on with what I have learned. When we go to tow mode we will get a lighter trailer, save gas and feel safe. Cheers to all.
amblt is offline   Reply With Quote
Old 10-14-2015, 11:09 AM   #22
Originally Posted by Kenny kustom View Post
Dollars to donuts, you are over too....
2008 F350 CCSB V10
2016 Sabre 36QBOK
How am I over and what am I over on? A statement like that is confusing. Could you elaborate?
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 10-15-2015, 01:01 AM   #23
OscarsMom2's Avatar
This refers to the pin weight of the 5th wheel as compared to the cargo capacity of the pickup.
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is offline   Reply With Quote
Old 10-15-2015, 08:07 AM   #24
Kenny kustom's Avatar
The problem with a 3/4 diesel is the fact that the engine weighs so much.
Eats up your payload.
With four adults, I only had 700 lbs left for payload.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 10-15-2015, 09:36 AM   #25
2008 F350 CCSB V10
2016 Sabre 36QBOK
My yellow sticker says my payload is 2290 pounds. My tongue weight when my trailer is the heaviest is 1285 (when full of water for traveling- a note though I have only filled my TT with water once for traveling but for this illustration I will use all the "high" numbers). I run the EQ 4 pt which is 78 pounds.
I carry two 2k's with gas and those are 100 pounds combined. I carry 3 bikes and those are 105 pounds combined. I carry one cooler with snacks and drinks that is 35 pounds and I put my sons plastic picnic table in the truck bed too, which is 15 pounds. Other than that it is just me my wife and my son in the truck and all of us are less than 400 pounds.
All of us and the truck gear is 655 pounds plus the highest TW of 1285 equals, plus the WDH is 2018 pounds total. 2290 - 2018 = 272 pound wiggle room (which is good because my sons 3 and he will get bigger).
I have been to the CAT scale unloaded, loaded, with and without WDH. I am intimately familiar with my weights (because on my old truck I was over) but I can say without a doubt with my new truck and setup I am not over.
Old 10-15-2015, 09:24 PM   #26
drittal's Avatar
Im assuming he assumed you had a 5er like the OP. If you had a 5er of the same weight, your wiggle room would be gone.
Have fun camping!
drittal is offline   Reply With Quote
Old 10-15-2015, 10:16 PM   #27
Have fun camping!
That makes a little more sense, I'd be looking at 25 percent of gvw instead of about 15 ish now. I can see that being eaten up quick.
Old 10-21-2015, 05:50 PM   #28
Total Loss's Avatar
This is the only "1/2" ton I would tow a fifth with. They do make them.
My old 04 F150 with a 10 3/4 rear end and a 3000 lb payload.
That truck drove very nice with or without a load.
I would put my Rzr in the bed and forget it was there.
Total Loss is offline   Reply With Quote
Old 10-21-2015, 06:11 PM   #29
Originally Posted by OldCoot View Post
Just keep in mind that there is no slack in the lawyer stickers, if you go 1# over the weight limit, the whole rear end will collapse and the engine will explode.
LOL. Don't bring any of that common sense stuff into this discussion, it is not welcome.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 10-22-2015, 08:09 AM   #30
2008 F350 CCSB V10
2016 Sabre 36QBOK
As long as you are aware of the fact that you traded your 250 for the exact same truck with an overload spring and possibly a 4" block instead of 2" more power to you. But if you truly think you are safer or more responsible than a 250 owner because your sticker says so I'd have to respectfully disagree.
