Old 10-22-2015, 07:13 AM   #31
Kenny kustom's Avatar
Excessive Pin Weight for 1/2 Ton ??
Originally Posted by dustman_stx View Post
As long as you are aware of the fact that you traded your 250 for the exact same truck with an overload spring and possibly a 4" block instead of 2" more power to you. But if you truly think you are safer or more responsible than a 250 owner because your sticker says so I'd have to respectfully disagree.
Sorry, but I go by the door sticker, same thing dot would if I got pulled over.
It's not just a suggestion.
I'll put this one on the scale next time I am in the city.
My ram was 7919 without me in it.
10k gross.
My 350 is 11 gross.
The 6.7 CUMMINS engine is 1150lbs dry
The V10 is 620lbs.
The ram had wimpy coil springs.
The 350 has leafs.
It all makes a difference.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 10-22-2015, 08:20 AM   #32
TURBS's Avatar
Originally Posted by Total Loss View Post
This is the only "1/2" ton I would tow a fifth with. They do make them.
My old 04 F150 with a 10 3/4 rear end and a 3000 lb payload.
That truck drove very nice with or without a load.
I would put my Rzr in the bed and forget it was there.
What? 3000 lb payload on a f150?
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-22-2015, 08:24 AM   #33
TURBS
2008 duramax
2015 columbus 320RS
That could be specd to do that.
They did have a "7700" package.
2wd long box, 7 lug wheels....
It was possible.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 10-22-2015, 08:24 AM   #34
Like I said, more power to you. I saw you have an F350 and I was clearly referring to a 250 to 350 transition, not a Dodge 2500 to a Ford 350 transition. You can actually get a 350 derated to a 10K GVWR- nothing changes but the sticker. The 10K limit on the 250 is about money, not safety, IMHO.
Old 10-22-2015, 08:29 AM   #35
B and B's Avatar
In my case the derated F 250 is about licencing and need for annual inspections as a truck over 10,000 lbs. My truck is equipped same as a F350 except 2 inch blocks, springs, diff etc are the same
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-22-2015, 08:32 AM   #36
B and B's Avatar
It was possible.
2008 F350 CCSB V10
2016 Sabre 36QBOK
I had a F 150 with 7650 GVWR package and 1600 lbs payload.
I have only seen 1 2WD with 8 ft and 7 lug wheels. The CCC was 2500 lbs.
Old 10-22-2015, 08:34 AM   #37
It was possible.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Actually, on the model '13 year and likely others, the MaxTow had a GVWR of 7650-7700 with that standard 6 lug wheels. You could get the HD Payload package that had 7 lugs and had a GVWR of 8200. What's funny is that the MaxTow got a 500lb bump in GVWR with NO structural changes whatsoever- confirmed through research of Ford lit and contrary to many confused opinions on the Internet. The HD did have structural changes, however.
Old 10-22-2015, 08:37 AM   #38
I'm fine with the annual safety.
Best inspection you could get for a hundred bucks.
I wish all vehicles on the road would be subject to annual safety.
Would take a lot of crap off the road.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 10-22-2015, 08:42 AM   #39
Me too. I just purchased a 2015 F250 with the camper package- meaning it is actually a 350 other than mine has the 2" blocks instead of the 4". My 250 actually has a 3.55 rear axle even though the 3.31 is standard on the 250 and 350. I could have spent an additional $3000 and gotten a 2016 F350(no 15's left remotely close to what wanted), but I felt that $3K was pretty steep for a sticker. I get a kick out of people thinking that DOT is primarily concerned with safety- they are concerned with revenue.
Old 10-22-2015, 09:01 AM   #40
Right. So what's a good way to increase revenue?
Hand out overweight tickets.
2008 F350 CCSB V10
2016 Sabre 36QBOK
