07-24-2016, 08:06 AM
#21
I never use cruise when towing, but that's just me. I like having control. As far as your problem, I think it's all just a coincidence. It was just it's time to fail. Nothing to do with what you were doing.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
07-24-2016, 08:23 AM
#22
Expensive mistake to make
I always use cruise control.
(Save for up and down big hills)
It's bad enough, we usually are going slower than traffic is. No need to make matters worse, by always going up and down a few clicks.
I hate following people that don't use cruise.
Faster... Slower... Nope faster..
The vehicle can do a better job at holding your speed, than you can. ( most cases)
As for the turbo? It was its time.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
07-24-2016, 08:29 AM
#23
I'm curious why those who don't use cruise, think it's a bad idea????
I use mine on flat stuff, wherever the drive is 'boring'...........if it ain't boring, I take it off. Just a preference. I don't like the sudden slamming of shifting, but again, a preference.
FROG AR-0019-242
07-24-2016, 09:00 AM
#24
IMHO the fact that your turbo blew under load was just coincidence. and the main question i have is if the truck caught fire why did you even try to put it out.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
07-24-2016, 09:03 AM
#25
A good working fire extinguisher and the ability/confidence to use it deserve honorable mention here.
Good job by the OP!
As for cruise control, I do not care for it. I can work the motor a lot smother with the gas pedal. I'm sure the use of cruise has a lot to do with your rigs weight and TV (gas or diesel). Just for me,rather not use it.
2016 Ford F250 Lariat CC 2WD 6.2L
Flagstaff 27 BEWS
07-24-2016, 09:07 AM
#26
Let it burn!!
2016 Sabre 36QBOK
07-24-2016, 09:10 AM
#27
Originally Posted by Kenny kustom
Let it burn!!
2016 Sabre 36QBOK
I agree. Maybe if time allows, unhook from trailer and get truck away from it. Unless you want a new one of those too of course.
07-24-2016, 09:16 AM
#28
Quote by W5CI "and the main question i have is if the truck caught fire why did you even try to put it out".
Why not?. If you have a chance to catch a fire on your rig (or anywhere) when it is small and you have the ability to extinguish that fire, then do it. I mean, yes I can stand back and watch my equipment burn and dial the insurance company before the fire is out or make an attempt to stop the damage and destruction. Sure it's a judgment call. If your'e worried about the truck "blowing up" like cars do in Hollywood, don't. It just does not happen. Sometimes no action is the best action, but not in this case.
Again, good job by the OP.
07-24-2016, 09:22 AM
#29
I not going to comment as to whether the 6.0L Powerstroke is a fair engine or not. I would like to know if you have Gauges on your truck?
If so what was the Boost pressure and EGT's readings?
I have driven over several mountain ranges that have had 6% to 8% slopes using cruise control with no issues. But I do watch my Boost pressure and EGT's on my truck and will down shift to 5th gear when the EGT's start to rise above 1200F, but I will keep my Boost pressure under 30 PSI.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
07-24-2016, 09:28 AM
#30
Originally Posted by mnoland30
Google Bullet Proof Diesel, or 6.0 problems. Once those problems are fixed, the engine should be good for 300,000 miles or so. I haven't done that yet, but I plan to.
I did just that to mine at 125,000 miles and that damn 6.0 pulls like a locomotive. One of the best things is no common rail fuel injection and no DEF.
07-24-2016, 10:20 AM
#31
Agee. EGT is the key to turbo and not lugging the engine. I don't use cruise control on 6% grades. I tend to back off and manage my temps.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
07-24-2016, 10:40 AM
#32
ill agree with everyone, not your fault, it was just its time, i would sell the truck though, did they replace the entire motor? running the motor out of oil will do damage quick. im also interested (if you want to say) did insurance pay for it to be fixed since it was a fire?
'17 Flagstaff Shamrock 21ss
'13 Grand Cherokee-5.7
07-24-2016, 12:27 PM
#33
Tyler & Connie Foxx
To answer your questions
I was ask a lot of questions about this post and I'd like to try to answer some of them.
First off this is the first truck I'd ever owned, I wanted the biggest truck I could fine so I wouldn't have trouble when I chose a really large TT with pulling it. I'm not a mechanic by I do a lot of my own work (brakes, rotor, shocks, oil changes, filter changes) and I have the tool to read trouble codes if they arise. When I bought the truck my machanic looked it over and liked what he saw so I bought it.
I put a lot of love and care if this truck, I always carry fire extinguishers in both the truck and TT, I also had pets with us when we were travling, I'd never let my truck go up in flames if I could prevent it, plus it was attached to our 1 year old TT that we love dearly.
Yes the insurance paid for all the damages, plus we have Good Sam mechanical insurance, who helped out as well, no they didn't replace the whole engine, they replaced the turbo, wiring harnesses, coolant tank, hoses, the FICM, dip stick, oil cap, and any other things that burnt in the area.
The second the turbo blew I was on the side of the road with the engine off, I had thought it was the transmission the blew when I saw all the fluid leaking out down below. But after I put out the fire and had a second to catch my breath and collect my thought and look at what truly happened, I realized it was the turbo. The ford mechanic said my fast action over getting over and turning off the truck prevented any further engine damage.
I wasn't aware at the time of purchase of the problems with the 6.0 engine, if I had my choice my have been different, but it was a one owner truck in fantastic shape that was well cared for, so I bought it. This was the first and only trouble it has ever given me. And just last month it turned over 100,000 miles. 😋
07-24-2016, 12:36 PM
#34
Tyler & Connie Foxx
My Ford F-350 Super Duty and travel trailer.
07-24-2016, 01:22 PM
#35
Like I said "good job".
You made a quick assessment/decision to engage with the equipment you had and made a good save of your truck and almost new TT. Nothing wrong with that.
A good drill for anyone towing anything is to see how fast you can pop your hood open. You'd be amazed how "elusive" that lever can be in an emergency.
Some are not as inclined to make the decision you did. And that's fine. But if I have a chance to make a positive difference, I'm in. If I'm in the right place and time,I will help anyone that I am able to without getting myself killed or injured.
That's sometimes the tricky part. But life is always playing tricks on us, right?
RMc
07-24-2016, 01:30 PM
#36
Originally Posted by prestonj12
I'm with most of the replies here. 6% isn't that much of a grade out West here. Shoulda been able to pull that hill down one gear from overdrive at maybe 1700 RPM.
Sent from my iPad using Tapatalk
Amen, we saw 8 % in the west.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
07-24-2016, 06:21 PM
#37
ive been around a lot of 6.0's if you make it past 110k without it starting to blow up the coolant tank you will prob be fine, they seem to be either headgaskets go early or never
07-24-2016, 09:13 PM
#38
Originally Posted by FoxxLandArk
I was ask a lot of questions about this post and I'd like to try to answer some of them. 😋
I think you did what all would hope to be able to do in that situation. Who would have thought that would happen.
USMC 68 -70
07-24-2016, 09:52 PM
#39
It sounds to me that the turbo had the original flex hose that can rupture, there is a $80 updated turbo feed line 3C3Z-9T516-A and an updated drain tune for $30 6C3Z-9T515-A. A 6.0L is a great engine, just maintain it. The oil cooler is the weak part, it clogs, overheats the EGR cooler and it ruptures allowing coolant to get in the intake and the head gaskets pop.
I have replaced my EGR cooler with a high flow unit and added an external oil cooler, coolant filter, updated FICM and other non power adding mods. I updated a lot of parts but I still have the torque to yield bolts at 140,000 miles and with regular maintenance I am a very happy 6.0L owner.
As for cruise, I use it all of the time on the highway but I use the pedal in the mountains. I do not monitor exhaust gas temps but I do monitor engine oil temps and coolant temps, when they start going up I back off the fuel.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
2018 25 2019 25
2020 24 2021 28 2022 302023 30
07-25-2016, 09:44 AM
#40
X2 on managing your EGT and not lugging it the hills. Oil that cools the turbo also get superheated if you run your EGT up, and consequently heats the oil for the entire engine.
Downshifting to a lower gear I see EGT temps go from 1100 down to 900 even on hills where the computer doesn't tell the tranny to drop down a gear.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
