Old 07-22-2016, 02:54 PM   #1
Tyler & Connie Foxx
FoxxLandArk's Avatar
Expensive mistake to make
A few months ago we were driving through TN, while towing our 40ft Salem Hemisphere to Florida for a vacation at Disney World.
While driving over a mountain know to the locals as "Million Dollar Moutain" with the cruise control set to 50mph, I failed to see a sign that said 6% grade ahead, trucks use low gear!
Not even half way up the Moutain I noticed our truck (Ford F-350 SuperDuty) was struggling to keep pace, it was at that moment I realized I was trying to go far to fast for the grade we were on. As I reached to switch off the cruise control there was a loud bang, then a lot of smoke!!! I immediately pulled over set the break and hazard lights, and jumped out to open the hood to find half of the engine on fire!!!!!!!
Come to find out that the turbo had blown spraying high-pressure oil over the engine causing a large fire and $11,000 worth of damage!!! I was able to put the fire out, but it ruined our vacation, and stranded the truck and trailer in TN for weeks while the repairs where done.
The moral of the story, Pay attention to roadsigns and don't be in a hurry when you're climbing steep hills!!! The fire department told me going up a hills that steep you should always locked out over Drive, I've driven large vehicles for a long time but never pulled a trailer with the truck so I was unaware that the same rules applied. Very expensive lesson to learn.
FoxxLandArk is offline   Reply With Quote
Old 07-22-2016, 03:57 PM   #2
Although locking out overdrive, using tow/haul, downshifting, etc. is ideal... you should not have had your engine blow up because of what you did.
The truck should have/would have/did downshift eventually on its own.
I strongly believe you just found a defect.
325BH is offline   Reply With Quote
Old 07-22-2016, 04:14 PM   #3
Ford Idaho's Avatar
I take it this was the 2003 SD with the 6.0 in your profile.
I think the turbo just let go, the truck should have made the climb even on cruse without issue.
How many miles on it?
Old 07-22-2016, 04:15 PM   #4
f5moab's Avatar
Was this an automatic trans? I agree with 325BH if it was an auto.
Most newer vehicles don't care what gear you have selected with an auto, if the parameters do not meet as designed into the trans controller. Outside those parameters the controller will shift gears regardless. That is true for overdrive down to a lower gear, or place it in 1st gear and keep accelerating, the trans will eventually shift into a higher gear.
Regardless, it is a shame you did not get to your location as expected.
f5moab is offline   Reply With Quote
Old 07-22-2016, 05:02 PM   #5
Tyler & Connie Foxx
I was told by the mechanic that because it was a 2003 Ford F350 super duty 6.0 , with 87,000 original miles, that the turbo may just have been at the end of it's life. But it was definitely the pressure caused from the cruise control downshifting the transmission that cause the pressure that blew the turbo. That according to ford
Old 07-22-2016, 06:19 PM   #6
Ford 6.0 worst diesel ford ever had. A lot of issues with that engine.
Big Red and 30WR is offline   Reply With Quote
Old 07-22-2016, 06:27 PM   #7
Carknocker Family
Ida Ratherbe Camping's Avatar
I would say they circled the problem, but it's too soon. Sorry for your loss.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 07-22-2016, 06:34 PM   #8
Retired JSO's Avatar
That 6.0 International engine that Ford chose to up the horse power/torque every year to keep ahead of the Dodge/GM trucks was the real problem. I had 2 of them over the years. That same engine is still powering most international school buses in service without many headaches.
Retired JSO is offline   Reply With Quote
Old 07-22-2016, 07:07 PM   #9
The international 7.3 was a lot better than the 6.0 Heard if you let the 6.0 idle too long it would dump diesel into the oil. Main reason I never bought one.
Old 07-22-2016, 07:53 PM   #10
I'm with most of the replies here. 6% isn't that much of a grade out West here. Shoulda been able to pull that hill down one gear from overdrive at maybe 1700 RPM.
Sent from my iPad using Tapatalk
prestonj12 is offline   Reply With Quote
