Here is my toad with my 2251
About 4000 lbs loaded with bicycles and gear. (2012 Toyota 4x4 manual with 4 cylinder)
I was impressed with the tow.
Felt the pull on hills and startup(3rd gear at 50 on the steepest hills) and the braking.
Do not have braking on the toad and it seems adequate.
I have to remove (or tie up- I have rigging) the rear driveshaft for long tows- Toyota 4x4's will burn up the rear main trans bearing if towed too far with
the driveshaft spinning.
