Old 10-18-2015, 07:37 AM   #11
I don't have the paperwork here with me, but as I remember my Ez lift instructions called for a minimum of 5 links between the bar and trailer. You need that length to allow for the swing when you make tight turns. If you find you're needing the chains shorter than that you may need to readjust the WDH setup.
Springerdad is offline   Reply With Quote
