Old 01-12-2015, 08:03 PM   #1
F 150 EB max tow info help
Looking at a 2011 Ford EB. Dealer state it is equipped with 3.73 axle and Tow Max.
How can I verify this? Is there a sticker on vehicle or do I need to decode the vin?
Thanks in advance
grumpyer is offline   Reply With Quote
Old 01-12-2015, 08:47 PM   #2
should be on the door jam on the drivers side. It will give you your max payload. I think max tow is right around 12k but the total payload rating will decide how much tongue weight you can handle
firedaniel is offline   Reply With Quote
Old 01-12-2015, 09:47 PM   #3
Stormrider151's Avatar
I don't know if this is included with Max tow but my 2012 came with the large towing mirrors. That's how I found mine on the lot. They are hard to find. At least where I live it was.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 01-12-2015, 09:54 PM   #4
If it is HD and has tow mirrors and brake controller, it has max tow.
HD will have 7 lug wheels and 17 inch tires.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 01-13-2015, 08:44 AM   #5
fx2
http://www.fleet.ford.com/maintenance/vin-decoder/
This should give you the rear end info. If it has the 3.73, the brake controller and the tow mirrors you have the MaxTow package. If it has the 7 lug wheels it has the HD payload package. Sounds like the one you are looking at has MaxTow, no HD Payload
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 01-13-2015, 09:01 AM   #6
The MaxTow will have the large tow mirrors- but they could have been added. GVWR sticker on door jamb will be 7650 or 7700 rather than 7200. The HD payload will have the tow mirrors AND 7 lug wheels. If an HD, GVWR will be 8200.
Edit: Just realized FX2 said pretty much the same thing. I concur- sounds like Max Two non HD Payload.
Old 01-13-2015, 12:07 PM   #7
how to look up the original F150 window sticker
Ford F-150 Window Sticker Generator
You will also need the VIN
I hope this helps
tbrew100 is offline   Reply With Quote
Old 01-13-2015, 12:23 PM   #8
Boso's Avatar
Max tow package has larger mirrors built in brake controller 3:73 gear 3.5 ecoboost 365hp tow 11300 lb also will be 18"tires 10 ply had one I ordered in 2011 mpg won't be as good because of the gear but it has plenty of power nice truck
Boso is offline   Reply With Quote
Old 01-13-2015, 12:34 PM   #9
Max-tow does not come with 10 ply tires
jaydubya is offline   Reply With Quote
Old 01-13-2015, 12:53 PM   #10
PSUFan1's Avatar
Thanks in advance
I just assumed as well if it had the max tow it would also have the max payload. Sounds like that isn't the case.
Is the 17" tire a good measure for the max payload. Cant tell the number of lug nuts on photos. Manufacturers sticker tells you tire size.
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
