Old 06-19-2015, 07:14 PM   #41
Originally Posted by CWSWine View Post
Here is a tag off of a 2013 Chevy LTZ with diesel and Z51 options where the web page said over 3100 cargo but the yellow tag on the truck said 2475. When I put the trailer below on the scales loaded with just the stuff that stays in the trailer the rear axle weight was 5980 with rated gross axle weight was 6200 of the 2500HD. Now with the F350 I have 7180 lbs rear axle gross weight ratings which gives me some breathing room.
I also notice that the Chevy locked out 6th gear in tow haul mode and the Ford doesn't. I just took a trip I took many times in the Chevy and the Ford only shifted into 5th gear a couple of times and stayed in 6th gear.
Please give more details on the duramax locking out 6th gear in tow/haul. I've had 5 duramax and none have ever done that
Sent from my SM-N910V
mustardbucket107 is offline   Reply With Quote
Old 06-19-2015, 07:38 PM   #42
CWSWine's Avatar
I had a 2013 Chevy 2500HD Diesel and when you push in the tow haul mode it would drop a gear into 5th gear. I first notice it when I was not towing and going 70 MPH and push tow haul button in the RPM would increase - take it out two haul the rpm would go back down. Then while towing on flat ground I could take it out tow haul mode then put back in tow haul mode and the RPM would drop till I hit hill then it would down shift back into 5th gear.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-19-2015, 07:41 PM   #43
That's odd, i have never had one do that, tow/haul only affected upshift/downshift rpms
Old 06-19-2015, 09:42 PM   #44
Ford V Ram
Just bought 2015 Ram 2500- 6.7 after owning Ford and now pulling same rig it is like nite and day. The 6.7 engine and 6 speed trans out pull my Ford by leaps and bounds. Might want to check out new truck deals compared to used, for the difference in price used wasen't worth it.
Just so fine is offline   Reply With Quote
Old 06-20-2015, 07:49 AM   #45
Ddubya's Avatar
What was your Ford?
Ddubya is offline   Reply With Quote
Old 06-21-2015, 12:24 PM   #46
2005 6.0
Old 08-01-2015, 07:54 AM   #47
fwiw, my 2011 Ford F-250 SD 6.7 Diesel has a payload sticker of 2878. It is SRW, 4x2, Supercab. Only once have I wished it was 4x4. I'm to old and the truck is to heavy to get it off road. I added a set of SuperSprings and Bilsteins shocks. Expectedly, neither Supersprings nor Ford will admit to a payload increase, but while they say no, there's that accompanying wink and a nod that I'm now equal to a 1 ton. When I asked the Ford service manager if adding the overload springs would increase payload, he nodded his head up/down while saying no.
Just sayin'
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 08-05-2015, 09:13 PM   #48
Ddubya's Avatar
The load capacity of 3/4 ton trucks is all over the place based on the equipment and accessories. I have a 2013 SRW 2WD 2500Hd Diesel that has a sticker rating of 2861 lbs. most are not that high. A loaded truck with 4x4 may be hundreds of pounds less.
Old 08-05-2015, 09:33 PM   #49
B and B's Avatar
Just sayin'
There are 2 F250 2014 Crew Cabs with Blistens parked close to me. They are towing 40 ft fivers weighing in at 16,000 with pin at 2500 lbs. I see no problem myself with this.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 08-06-2015, 09:08 AM   #50
CWSWine's Avatar
I agree I had 2500hd diesel with 2475 pin weight and after I installed a fifth wheel hitch and me and my wife my CCC went under 2,000 lbs to say under the GVWR of 10,000 lbs.
My F350 diesel has a CCC of 3744 and with hitch loaded went to 3200 lbs.
500, diesel
