I'd get Forscan. About $35 for the lowest cost adapter. Then you can make some other nice changes: disable the horn honk if you get out of truck with engine on and close the door, enable fog lights with hi-beams (bambi mode - good for seeing side of road at night), turn on display of oil and tran temps, door ajar warning with engine on, disable fake engine noise, secure idle enable (cannot put truck in gear if fob is outside of the truck - push button start trucks), etc...
Also can be used to get correct speed display if changing tire size. Many others.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
