Old 12-12-2014, 11:11 AM   #1
Scootdawg's Avatar
F150 Firestone Riderite Airbags
A while back someone posted having an F150 with Firestone Riderite airbags and Rancho RS9000XL adjustable shocks on their TV pulling a 5th wheel. I was wondering the model of them. A person that I am having install them for me had me contact a truck shop and they ordered the 2525 model. I have a Reese 16K hitch and it doesn't look like they will fit with the hitch plate that is on the frame. I looked at the review for the airbags model and some people say they work great pulling their 5ver with them, but different hitches have different configurations. I guess I am a little stressed over a part that might not work.
2014 F-150 SuperCrew
2015 Rockwood 8289WS Diamond
Scootdawg is offline   Reply With Quote
Old 12-12-2014, 11:33 AM   #2
Flagstaffer06's Avatar
If you don't have any luck on here, try looking on etrailer.com. I had no intention of pulling a 5er with my truck but, I know when looking at the different models it listed if it would or wouldn't work with a 5th wheel hitch installed. With regards to my truck, I know the Firestone's would work but, the Airlift brand wouldn't.
Even if you aren't sure or don't get information you can even send those guys a message on there. They are quick to respond and will help you out, even if you don't buy from them.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 12-12-2014, 11:35 AM   #3
I found this on E trailer:
I do have a rear suspension enhancement option for your 2013 Ford F-150, however, the Firestone Ride-Rite Air Helper Springs, # F2525, are not compatible with most fifth wheel frame brackets that mount to the outboard side of the vehicles frame rail. Most fifth wheel brackets block the frame and it is not recommended to install the Ride-Rite kits on top of fifth wheel brackets.
According to my Firestone representative, the only difference between the # F2542 and the # F2525 is that the mounting brackets on the F2542 are a bit different to allow a B and W fifth wheel hitch or a fifth wheel hitch with the # RP30035 universal brackets to be installed. The Firestone # F2525 would not be compatible with frame brackets for a fifth wheel hitch.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 12-12-2014, 12:14 PM   #4
Scootdawg's Avatar
Thank you all for the input, that is my luck. I talked to the parts salesman and he mentioned the RP30035 universal bracket which I do not have. Looks like I will turn these in and try the shock upgrade.
Old 12-12-2014, 12:24 PM   #5
I have Ride-rites and the RS9000XL's but I pull a TT. The Rancho shocks will help with porpoising, but keep in mind that shocks offer no additional lift. You might look into adding some helper springs such as these: Hellwig EZ Level Helper Springs - Best Price on Hellwig Overload Springs - EZ 550, EZ 990, EZ 1000
Old 12-12-2014, 06:22 PM   #6
Ddubya's Avatar
I have Firestone bags on my 2011 F250 with Reese 16K. I had no problem installing them.
Ddubya is offline   Reply With Quote
Old 12-13-2014, 11:44 AM   #7
rsdata's Avatar
airbags are the way to go...
I have Airlift brand Loadlifter bags installed and love the wya they make my TV handle while pulling my trailer. They come in many different flavors for different applications. I looked up what I needed on airlftcompany.com then ordered on amazon for the best price.
Old 12-14-2014, 07:31 AM   #8
Scootdawg's Avatar
I have a plate mounted to the frame that hold the hitch down. No room for the airbags to mount on the springs to the frame.
Old 12-14-2014, 08:03 AM   #9
Shinny's Avatar
etrailer told me the same thing for my Ford. They were wrong!!! Look at your frame where the hitch plate is mounted. If the frame has an inward bend, then you can use the air bags. The hitch plate will have to be removed so you can mount the bag's bracket, then re-install the hitch plate. The bend in the frame allows the air bag mount bolt head to sit under the hitch plate. I will take pics today and post them since a lot of people have the same question and are being told they won't fit.
2015 Sierra 32QBBS-23 nights camped since the end of June 2014
2015-sorry to say only 11 nights so far, more to come though
Shinny is offline   Reply With Quote
Old 12-14-2014, 10:16 AM   #10
Scootdawg's Avatar
Thank you very much, if its just removing the plate then install the bags and reinstall the plate, it saves a lot of hassle.
airbags, f150
