Old 07-04-2016, 05:20 PM   #1
F150 FOS?
Looking at new tow vehicle for a 7300lb TT. Ford says 2016 F150 with 6 cyl 3.5L ecoboost and 3.55 ratio and their heavy duty payload pkg can pull 12,000lbs conventional. Are they FOS? Doesn't seem possible to me that a tow vehicle weighing <5000lbs with a six cylinder could pull that big a load going uphill at hwy speeds.
Mazonator is offline   Reply With Quote
Old 07-04-2016, 05:51 PM   #2
bikendan's Avatar
As with any 1/2 ton, PAYLOAD will be the limiting factor, not towing capacity.
But the Ecoboost has proven to be a quite capable tow vehicle.
Equalizer WDH
Old 07-04-2016, 05:58 PM   #3
crunchman12001's Avatar
For a TT that size, I would recommend a F-250 - 3/4 ton. As stated, you will need the payload capacity.
2015 F-250 FX4
Old 07-04-2016, 06:41 PM   #4
I tow a similar sized TT with the 3.5 Ecoboost. Power isn't the issue, but the weight of the truck vs the weight of the TT means that it's not all that fun for long trips. Also mpg drops from AV 19 when not towing to less than 9.
jlnrose is offline   Reply With Quote
Old 07-04-2016, 06:52 PM   #5
Sky&Scuba
kendive's Avatar
Agree I also own the F150 Eco 3.5 and it has all the power you would ever want and or need to tow anything, But if you are going to be towing alot of weight and a trailer over 30 feet there are some things I would upgrade. Such as Rear Bilstein 5100 shocks, Rear Hellwig Sway Bar, and Airbags in the rear.
These little self install items make a tremendous change to the towing and handling of the truck. Rock Solid!!!
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
f150
