Old 09-10-2016, 07:50 AM   #1
n4uaj's Avatar
F150 noise when towing
When towing, my father in law's F150 makes a scrubbing noise going over bumps in the road. He was thinking it was bottoming out and scrubbing the tires but there are no marks on them and in my opinion the truck sits high enough that there is no way it would touch the tires. I'm thinking rear spring noise. Anyone else experiencing this?
Bill
2014 Shamrock 183
1995 Chevy Silverado
n4uaj is offline   Reply With Quote
Old 09-10-2016, 08:29 AM   #2
Towing what? Weights might help.
donniedu is offline   Reply With Quote
Old 09-10-2016, 04:05 PM   #3
n4uaj's Avatar
It does it with either my Shamrock 183 or his 98 Jayco 23. He says it used to do it with his two horse trailer too
Bill
2014 Shamrock 183
Old 09-10-2016, 04:11 PM   #4
Cyber Phrenologist
Radio's Avatar
Wondering out loud:
Could it be the shocks?
Is the axle coming into contact with the frame bumpers?
Could it be something in the hitch set up?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 09-11-2016, 03:33 PM   #5
jftrombley's Avatar
The truck could be too high and the rear bumper or hardware on the back of the trailer could be dragging.
jftrombley is offline   Reply With Quote
Old 09-11-2016, 04:30 PM   #6
I had a 2001 Ford F150 that developed a noise in the left rear. Upon inspection the rear spring bracket had broken and spring was pushed up against the bottom of the truck bed. Surprisingly, this only gave the truck a slight lean.
When I was having the bracket replaced at a truck spring shop I asked if this was common and he said they did 5 to 6 per week.
CNYCamper is offline   Reply With Quote
Old 09-11-2016, 05:52 PM   #7
jftrombley's Avatar
Own 3 F150
F150's have front suspension issues with ball joints, rivets and steering bushings. Grease everything you can. When towing the truck level changes and so does the suspension. Unless the truck is self leveling.
One issue I remember was a recall was for a drivers side frame rivet that was not correctly installed. It made a pop noise and the fix was a weld.
Another issue was ball joints which is very common with F150's. To check raise the front and see if you can move the wheel up and down or in and out. If it has play replace it.
The rubber bushings in the front end can maKe noise. Grease the zerk fittings
It could also be shocks. With the truck ready to tow the camper, jump up and down on the bumper and see if you hear the noise.
Good luck
Old 09-11-2016, 06:25 PM   #8
An acquaintance told me his neighbor broke a rear leaf while crossing railroad tracks with his 2015 F150. The truck had no load in the bed and no trailer. This gentleman heard an abnormal sound as he went over the tracks but afterwards it seemed OK. A week or so after he was towing a boat and noticed a sound like a tire rubbing the frame.
I did not see it myself and can't confirm it but it sounds similar to your complaint. You may wish to check for a broken leaf.
Ken
kenh is offline   Reply With Quote
Old 09-11-2016, 08:14 PM   #9
It could also be a u-joint or even the drive shaft rubbing when the truck bed is depressed. Take s close look.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
f150, noise, towing
