Old 08-19-2016, 08:56 PM   #41
CaptnJohn's Avatar
Originally Posted by Buzzard Bait View Post
Well, that certainly clears things up! �� Really, thanks for all the input. Think I'll wait on the 2017 250 comes out and give it a test ride. I think I read somewhere that you wouldn't need a WDH with the 250. Seems pretty extreme for a 34' 8000 pound trailer.
I'll look at mine during daylight but ~~ I think my F350 says 8500 without a WDH. Now ~ there are 2 inserts from 2" to 3" bars..
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 08-19-2016, 09:06 PM   #42
So what's the issue with the 250 gas engine?
I had an F-150 with the ecoboost great truck but traded up to an F-250 Diesel. Best decision I've made. I now have a bigger tow capacity more power and we have moved up to a 5th wheel. Diesel is best for mountain pulls as well. In a week and a half we are headed for Yellowstone with the new rig.
leeman is offline   Reply With Quote
Old 08-19-2016, 09:41 PM   #43
CWSWine's Avatar
Originally Posted by tbln930 View Post
Other than maybe the new 2017 F250 I would also skip right to the F350 as you did if I went to a large fifth wheel some day instead of the 37' TT we have now. My F150 max tow is 11,200 (Screw) and 3160 payload but the max rear axle load is 4050#. I am about 20% below most of the max weights but Ford told me to stay a minimum of 10% below the chart for ease of mind. The max WDH hitch weight is 1130#. Any fifth wheel of the same length would be pushing or over the limits.
t
There is something seriously wrong with your numbers you are posting. First a F150 a 3160 payload and not being a HD Payload truck with a 4050 axle weights. If that is the correct payload numbers it would mean that you rear axle weights unloaded would be some where in the 600 to 800 lbs range and they should be around 2200lbs. You need to look at your door jam at the yellow sticker and that your real payload numbers for your truck, those numbers on the website are not real world numbers.
Also that 11,200 lbs towing is based of a 150lbs driver and base truck with zero options. To find out the real max towing weight you would have to know the weight of your truck ready to camping and subtract it from the Gross Combined Weight Ratings and that will give you the Max Tow Ratings (truck and RV together) for your truck not some website stripped down truck.
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
Sold - 2014 Cougar SGS
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 08-19-2016, 09:46 PM   #44
kho6658's Avatar
Well, that certainly clears things up! 😳 Really, thanks for all the input. Think I'll wait on the 2017 250 comes out and give it a test ride. I think I read somewhere that you wouldn't need a WDH with the 250. Seems pretty extreme for a 34' 8000 pound trailer.
You can have one today for just a few $$$
2016 Freedom Express 28SE
2013 Expedition EL
Days Camped 2016 - 35
Days Camped 2015 - 20
kho6658 is online now   Reply With Quote
Old 08-19-2016, 09:55 PM   #45
LTnTN's Avatar
If you're in the mountains a lot, you'll need the engine braking from the diesel.
2015 Flagstaff 8528RKWS
2013 Ford F-150 Ecobeast
LTnTN is offline   Reply With Quote
Old 08-19-2016, 10:48 PM   #46
CaptnJohn's Avatar
Attachment 117866
Higher than my 2016 F250 but a little lower than my 2016 F350. As my wife says ~~ "you can tell the age of the boys by the price of their toys".
2016 F350 diesel
Old 08-19-2016, 10:57 PM   #47
CWSWine's Avatar
I saw that in one on the promo videos that WDH not required for 2017 F250 and F350 HD trucks. I think I will take a wait and see on that claim and be waiting to hear the reviews from real world experiences.
Old 08-19-2016, 11:36 PM   #48
CaptnJohn's Avatar
If I were to ever pull a TT again, I'd still use a WDH with sway control,,, no question on a single axel over 1500#.
2016 F350 diesel
Old 08-20-2016, 05:40 AM   #49
crunchman12001's Avatar
Originally Posted by pacin View Post
I happen to like my gas f250.
X2
2017 Salem Villa Estate 395RET- Ordered - Coming soon
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 08-20-2016, 06:19 AM   #50
shorthorn's Avatar
From my understanding, the new Fords claim that a WDH is not needed because they increased the receiver size to 3", and thus the hitch itself can handle heavier tongue weights. That does not mean the rest of the truck can handle it. It also doesn't mean that you don't need sway control, nor does it mean that you won't unload the front axle, overload the rear axle, or just shove the rear axle down on the bump stops with a really heavy trailer... unless they have an air suspension option.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
f150, f250
