Old 04-19-2015, 08:37 AM   #1
Olpete's Avatar
F150 payload question
With Ecoboost, does adding the max trailer pkg increase both TV payload and TT loaded weight or just trailer weight? Same question for HD payload pkg? Any idea by how much for either pkg.
It seems to be impossible to know the TV's payload capacity before delivery of the truck and checking the yellow sticker. That is the message The dealer gave me.
2013 F150, 4x4, Supercrew, Lariat, 3.31, Eco, 7200#
1000/10000 Equalizer WDH
2015 Flagstaff Shamrock 233S
Olpete is offline   Reply With Quote
Old 04-19-2015, 08:52 AM   #2
Canadian Member
itat's Avatar
They are separate packages with different purposes. Max. Tow increases towing (i.e. pulling) capacity and functionality with things like a trans cooler, Class IV? hitch receiver and towing mirrors. The Max. Payload package beefs up frame, suspension, axles, wheels, tires, etc. for more load capacity in the bed and on the hitch.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-19-2015, 10:31 AM   #3
Dave_Monica's Avatar
Don't know the GVWR numbers for the new aluminum bodied F150's but the max trailer package increased the GVWR from 7200# to 7600#...max payload package changed the GVWR to 8200#. I'm referring to late model ecoboost F150s.
Dave
Old 04-19-2015, 11:32 AM   #4
Olpete's Avatar
Thanks Dave,
I think my strategy will be to find an F150 with the options I'd like to have (w/o max tow or HD) on a dealers lot to see the capacity on the yellow sticker that way and then add the improvements in capacities you've described for max tow and HD to it to get the best estimate of the overall payload capacity for a similarly equipped F150. Does that make sense?
Old 04-19-2015, 12:11 PM   #5
B and B's Avatar
I can speak to both. After much discovery the King Ranch package as sold in in Canada is not available as the Max Payload is included in the King Ranch. Same axle and same springs as Max Payload. The Max Tow has the extra cooling capacity, mirrors and the brake controller. The Max payload as package is only available in long box version.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-19-2015, 01:48 PM   #6
fonzie's Avatar
Maybe this will help in figuring out capacities....
http://www.fleet.ford.ca/resources/f...Tgde_Sep30.pdf
Fonzie
Old 04-19-2015, 02:03 PM   #7
My 2013 MaxTow has a GVW of #7700. For that year, the same truck without the MaxTow had GVW of #7200. They HD Payload option was #8200.
tragusa3 is offline   Reply With Quote
Old 04-19-2015, 02:03 PM   #8
I believe the max payload is available with the 8' box and regular and supercab and the 6.5' box on supercrew. As far as payload capacity, it will reduce in any cab configuration as you add options, accessories by virtue of heavier weight.
Dave
Old 04-19-2015, 03:34 PM   #9
Maxtow increases payload by 500 but rear axle by only 200, so keep that in mind. Max payload increases rear axle 750 over max tow. Big difference. At least through 2014 models.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-19-2015, 03:51 PM   #10
Stormrider151's Avatar
If you need a reference point. My 2012 FX4, ecoboost, super crew with a 5.5 box has a payload of 1708 lbs. Take that with a grain of salt though. No 2 are alike.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
f150
