Old 09-07-2015, 08:55 PM   #21
B and B's Avatar
I would say no. I Pulled the same trailer with a F 150 Ecoboost and 3.73, added LT tires. Towed it just fine, some white knuckle moments with crosswinds in Near Northern Ontario. The limiting factor is no tow package, wrong Differential and the 5.0 l engine.
Even though I had all towing packages available it was not right and I was overweight on the CCC.
I would wait on a upgrade in TV prior to getting a fifth wheel.
I have a F 250 now and 1500 more pounds CCC. Tows like a trooper.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 09-07-2015, 08:56 PM   #22
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Originally Posted by stealthWA2313 View Post
I don't know about that. My F150 has 13.8" front rotors and 13.7" rear rotors. Your 2500 has 13.8" front rotors and 14.17" rear rotors...NOT a huge difference. I don't have exhaust brake, but with the "Selec-shift" transmission I can keep my #7500 trailer under 50 mph on a 10 mile 5% descent...without applying the brakes. With the right technique I really don't see braking an issue in this case.
The only issue I see is the 3.55s
I think the original issue was trailer braking. Your trailer brakes are your secondary brakes, not primary. Never set them stronger than your TV brakes unless you want to see your trailer pass you on a wet curve.
Regardless of the specks, if you put the 1500 and 2500 HD Duramax side by side, the 2500 HD brakes are larger as is the drivetrain. I did this when I bought my 2500HD to see if there was a difference. I do believe the callipers are larger too.
I was weighing whether to buy a 1500 with tow pac or the 2500HD Duramax/Allison. No comparison. Huge difference especially in the drive train. Rear end is 3.73. In tow mode with exhaust brake on, braking is never a problem. It figures it out without my input. The Allison 1000 transmission handles it all.
I haul an 11,000 lb TT
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 09-07-2015, 08:59 PM   #23
Left Coast
Manual 2nd gear also works
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
