Old 03-14-2019, 03:42 PM   #1
F150 question before purchase of new trailer
Hello-New to the forums. I have a 2018 F150 Platinum 3.5 10cy and am considering the purchase of a new Rockwood Mini 2509S. I am new to this so please bear with me. I tried to research and gather all of the facts that you wonderful people may need to assist me on. Sticker is attached. Hitch info attached. Appreciate you educating me on this nerve wracking process!
Trailer is:
Dry Weight of 5300
GVWR 6869
Hitch Weight 709
Length 25'11
Sparty9 is offline   Reply With Quote
Old 03-14-2019, 03:52 PM   #2
I cast see the truck specs well enough the read it on my tablet. That looks like a good hitch though. Where you may run into trouble is cargo capacity of your truck. This seems to be the biggest problem with towing an rv with a half ton.
2017 Wildwood 30KQBSS
2019 F-250 XLT 4x4 crew 6.2L
Wifshowfur is offline   Reply With Quote
Old 03-14-2019, 04:20 PM   #3
SailorSam20500's Avatar
I have a F150 Plat with PL of 1554 lbs. My trailer is a bit longer and heavier than what you are asking about. I'm under all my weight limits with this combo. I use a ProPride hitch. Truck and trailer work very well together.
I'll suggest you consider either the Propride or Hensley. There are currently used ones for sale in the classifieds on this site. Check other RV sites, they come up for sale fairly regularly as folks move up to 5th wheels or just sell their trailer. One just sold on myrvtalk.com for $700. Lots of Airstream owners use them.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 03-14-2019, 04:32 PM   #4
Recently went through this exercise
I just recently went through this exercise when we sold our last camper and purchased a new one so I will help the best I can.
You are on the right path by determining your payload by looking at the sticker on the door. I'm sorry, but I could not see your truck's payload capacity either via the image. Don't trust the manufacturer's brochure as they don't calculate gas, other fluids, and add on's. What I did to calculate the true payload of my truck is go to a scale and weigh the truck with me in it. I then subtracted that weight measurement from my truck's Gross Vehicle Weight Rating (GVWR) to determine my actual payload capacity (less my weight). The nice thing with going to a scale with just the truck is you can determine the weight on the axles of your truck as well without the camper.
In calculating payload you need to determine the weight of your passengers, cargo in the bed, and tongue weight of the trailer which I've been told is generally around 13% if you load the camper appropriately. After you determine those numbers you can ensure the truck is under the appropriate GVWR.
Don't rely on the dry weight of the trailer as that number is meaningless. Depending on how much you load in the camper, batteries, loaded propane tanks, etc. that is your true weight of your camper. To be safe I add in 1,000 lbs of additional weight of cargo in the camper to come to my weight of my camper; you may need to adjust for that.
Thereafter, you can figure out your tongue weight of your TT. Then you can add the weight you calculated for your TV and TT together to make sure you are under the Gross Combined Weight Rating (GCWR) of the truck. If you'd like I created a spreadsheet on this which I can email you if you PM me. It won't allow me to attach it to this post.
Finally, I have had great luck with the Equal-i-zer weight distribution system. I can't speak to other systems. Best of luck to you!
GreenHorn Hauler
Missouri
TV: 2014 Chevy Silverado Crew (5.3L), 4X4, 6.6 bed, trailer package and break
TT: 2011 Coachmen 28DDS
GreenHorn Hauler is offline   Reply With Quote
Old 03-14-2019, 04:54 PM   #5
dbledan's Avatar
I am right with your weight and vehicle wise but have a 2016. I agree with sailersam20500.
I had some sway issues with cross winds using a blueox swaypro and the propride resolved that. Do you have the 5.5 or 6.5ft bed? longer will mean more stability.
You can do it but you will want to weigh once you get setup just to verify. My first trip I was over so I left the tools behind to make weight. I still watch my weight because I tend to overpack. I spent a season with the blueox before upgrading and best money I spent was the propride.
I also added suspension support to keep my headlights low. Truck squatted a lot.
dbledan is online now   Reply With Quote
Old 03-14-2019, 05:10 PM   #6
Thank you for the great info so far. Iíve uploaded two additional photos. As far as passengers would be wife, two kids and myself for 450lbs total along with tonneau hard cover truck bed would be virtually empty.
ID:	198759   Click image for larger version
Old 03-14-2019, 05:31 PM   #7
Get a $3000 propride hitch.
Old 03-14-2019, 06:10 PM   #8
Equalizer (brand) 1000/10,000 pound hitch and you're good to go. The 3.5EcoBoost F150 can pull this trailer all day at speed limits plus on any paved grade in North America.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 03-14-2019, 07:36 PM   #9
You look like you are fine...but you are close! Definitely measure your tongue weight at some point. I bought a Sherline scale so I can measure my tongue weight after I do modifications to my trailer and add a full tank of water.
You are correct in adding the weight of all the passengers including the driver. Some people think the payload includes a 150# driver. That is false. A 150# driver is only used for the towing capacity...not the payload.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 03-14-2019, 08:58 PM   #10
Yep, payload is payload. No free passengers. Even those McDonalds french fries you spilled between the seats gotta be figured into what's left.
-- Chuck
f150, trailer
