Old 03-14-2014, 06:15 PM   #1
bld
f150 towing a 8289ws
we just bought a 8289ws 2013 our truck is f150 5.5 box 6.2 engine what hitch works trailer has a reese revolution pin box
getting lots of conflicting options
bld is offline   Reply With Quote
Old 03-14-2014, 08:01 PM   #2
WFD
oh boy have you opened up a can of worms!!!!!
Rick
WFD is offline   Reply With Quote
Old 03-14-2014, 08:04 PM   #3
CZNEDY's Avatar
Take a look at the reese 16K. If you google videos for the reese revolution you will find a few videos from reese
2018 BERKSHIRE 34QS
2004 Jeep Wrangler and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 03-14-2014, 08:08 PM   #4
CZNEDY's Avatar
Here is a link for you
Installing a Reese® Revolution Wedge - 30850 & SWW series - YouTube
2018 BERKSHIRE 34QS
Old 03-14-2014, 08:10 PM   #5
B and B's Avatar
I have a Reese. Tows like a charm, not much chucking occasional clunks. Lube up the revolution well, that can creek and make some noise.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-14-2014, 08:18 PM   #6
bld
do you have the 5.5 box ? i think a lot of the dealers " salespeople " have no clue
need to find someone that has that trailer and truck
Old 03-14-2014, 08:21 PM   #7
CZNEDY's Avatar
As far as the hitch and the pin box, the 5.5 bed is fine with the revolution without a slider. I am only commenting on the king pin and hitch
2018 BERKSHIRE 34QS
Old 03-14-2014, 08:37 PM   #8
bld
one dealer says the only hitch that works with the ford 5.5 box is the 12 k superglide auto hitch ? any thoughts
Old 03-14-2014, 08:47 PM   #9
Use a std Reese 16K with my short bed Silverado and the Revolution activated. No need for a slider. Even have a full bed hard cover tonneau cover on while towing.
ID:	47732   Click image for larger version
Old 03-14-2014, 08:51 PM   #10
B and B's Avatar
I have a 5.5 box and Reese Revolution using a Reese Revolution mounted with Pucks, no rails and NON SLIDER. I can turn 90 Degrees while backing in. As far as the Revolution if you wedge is setup correctly, lubed you can unhitch on a angle. I would highly recommend hitching up straight on.
Your dealer may not understand the Reese Revolution and how it works. OC tows with a revolution and may be able to add something as far as hitch choices.
BC and BC
OC was adding while I was writing..
f150, towing
