Old 08-13-2016, 03:31 PM   #1
F150 towing fifth wheel?
who out here can tell me if we could tow a light weight fifth wheel in a 5.5 ft bed in a f-158 crewcab ?
DAPYES is offline   Reply With Quote
Old 08-13-2016, 03:43 PM   #2
CWSWine's Avatar
There is a 5th wheel hitch that will allow you to tow one in 5.5 ft bed but the real problems is payload weights of the F150. If you look at your payload yellow payload sticker and get the payload numbers then go this website and be honest with your numbers you will see how big of 5er you can tow and stay within you trucks specs.
Towing Calculator based on Truck's Payload/CCC - Towing Planner
There are F150 that can tow good size 5er but payloads range for 1200 lbs to 2500 lbs with different options on the F150s. There still is the question should you but if within your truck specs the only person can answer that is you.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 08-13-2016, 07:50 PM   #3
CWSWine's Avatar
Here is a list of payloads that are found on the yellow sticker on the door jam. It’s 5th grade math and not some sort of rocket science to staying within your truck specs when towing a 5th wheel. These figures are with one 200 lbs driver and 250 lbs hitch with a 5er loaded ready to go camping and nothing else in the truck.
The numbers below came from Tow Planner - Towing Calculator based on Truck's Payload/CCC - Towing Planner
Payload = 1200
You're adding approximately 450 lbs. to the truck. You have 750 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 3,000 - 3,750 lbs.
Payload = 1400
You're adding approximately 450 lbs. to the truck. You have 950 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 3,800 - 4,750 lbs.
Payload = 1600
You're adding approximately 450 lbs. to the truck. You have 1,150 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 4,600 - 5,750 lbs.
Payload = 1800
You're adding approximately 450 lbs. to the truck. You have 1,350 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 5,400 - 6,750 lbs.
Payload = 2000
You're adding approximately 450 lbs. to the truck. You have 1,550 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 6,200 - 7,750 lbs.
Payload = 2200
You're adding approximately 450 lbs. to the truck. You have 1,750 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 7,000 - 8,750 lbs.
Payload 2400
You're adding approximately 450 lbs. to the truck. You have 1,950 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 7,800 - 9,750 lbs.
Payload 2500
You're adding approximately 450 lbs. to the truck. You have 2,050 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 8,200 - 10,250 lbs.
Payload 2600
You're adding approximately 450 lbs. to the truck. You have 2,150 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 8,600 - 10,750 lbs.
Payload 2700
You're adding approximately 450 lbs. to the truck. You have 2,250 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 9,000 - 11,250 lbs.
Payload 2800
You're adding approximately 450 lbs. to the truck. You have 2,350 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 9,400 - 11,750 lbs.
Most 5er loaded ready to camp comes in around 22% to 23% but there are some like front living room and rear kitchens that can run lower.
This explains a lot of the numbers http://rvsafety.com/rv-education/mat...ks-to-trailers
Old 08-13-2016, 08:13 PM   #4
Blackrock's Avatar
It can be done but will need to keep the weight down on the front of the trailer in order to keep your pin weight within reason.
I just returned from a 12,550 mile trip up to Alaska with a 1/2 ton Dodge Ram pulling a 30 foot fifth wheel.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 08-13-2016, 08:48 PM   #5
Canadian Member
I was in the same position Spring 2015 trying to decide on our next RV. My '09 F-150 has the 5.5' bed and a lower payload number than current F-150s with the all aluminum body. I decided to stick with a TT but even with that, as I recently discovered when I took our setup to a CAT scale, we are over the GVWR and the rear axle weight rating by a couple hundred pounds.
The first problem you'll have is with payload capacity. I suggest you look for rear kitchen 5th wheel models that tend to have the lightest pin weight by putting all the heavy appliances well behind the axles. Fully loaded, a rear kitchen model will still be north of 1000# on the pin.
The second problem you'll have is that with a 5.5' bed you can't use a slider hitch and the hitch will be very close to your cab. So you'll need to either look for a 5er with a Reese Revolution pin box or buy and install the aftermarket version called the Reese Sidewinder. These pin boxes are exactly the same and they move the pivot point back a couple feet but you'll still need to be extra cautious in tighter turns.
Good luck with your decision.
2019 Rockwood Signature 8290BS
itat is online now   Reply With Quote
Old 08-14-2016, 04:08 AM   #6
Big Rig's Avatar
No no no nooooooo!
Big Rig is offline   Reply With Quote
Old 08-14-2016, 05:47 AM   #7
bikendan's Avatar
it comes down to the payload capacity.
this is what cancels most 1/2 tons from towing most 5th wheels.
only the smallest/lightest 5th wheels will have a pin weight that some 1/2 tons can handle.
Equalizer WDH
Old 08-14-2016, 01:18 PM   #8
tom50mg's Avatar
I do,works great with the 08 5.4 liter,30 Foot 8528 fiver,several trips south now!
tom50mg is offline   Reply With Quote
Old 08-14-2016, 01:33 PM   #9
Dr Travel
Look - you naysayers can bitch all you want, but I have been towing a lightweight (7850 lbs) 32' fifth wheel for two years now with an F-150 Ecoboost with heavy duty tow package. Have racked up over 12,000 miles towing, another 45,000 riding around. Get between 10.5 and 11 mpg. Mileage towing has improved in last four months. We have a super crew with a 6.5' bed, and often have visitors/friends that we share rides with when not towing. Love my truck, love my fiver - Rockwood Signature 8280WS, rear kitchen. Not. One. Single. Problem. Oh, wait. Truck stopped working at the top of Mount Washington, had to be towed down on a flatbed truck. The control panel computer that runs the fuel pump had stopped working. Dealer installed in a day, piece of cake. Not a result of towing...
Did I mention we are full-timers? We live in our Rockwood and our truck, our only vehicle. A 2014 cost us $33,500 brand new.
robsshots is offline   Reply With Quote
Old 08-14-2016, 03:49 PM   #10
Three words. DON'T DO IT.
PERIOD
Springerdad is offline   Reply With Quote
