Old 09-30-2012, 08:54 PM   #11
Stormrider151's Avatar
You ALL make valid points and I appreciate each of them. It seems as though each has a different reason as to preference and they are all good. The "why buy a dump truck when all you need is a wheelbarrow" was great. while the 250 seems the "safer" bet. The cost may be prohibitive. I haven't talked numbers with a dealer yet. I did some looking after reading your responses and was surprised that the capacity gains were as small as they are with the 6.2 gas burner. Diesel is a whole different animal. Thanks to each of you, I now have some thinking to do:-)
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 10-18-2012, 09:45 PM   #12
So after much research and talking to owners I got an F150 FX4 with the max tow and the ecoboost engine. Taking a chance for sure. But the truck is a towing animal. I never would have believed it. But what everyone said appears to be true. I did take the extended warranty for safety sake. So far all is well.
Old 10-18-2012, 10:54 PM   #13
Twisty's Avatar
Did you get the Max Payload also?
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 10-18-2012, 11:26 PM   #14
I once saw a Freightliner Conversion RV Hauler hooked to a 32 ft Fifth wheel. Just above the running boards was written in large "biblical" looking font:
It's better to have more truck than you need than to need more truck than you have!
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 10-19-2012, 09:38 AM   #15
Yep, if it had max on it I got it. Going by the ratings it should be able to tow two 23ss trailers at the same time. Or get close to it. I talked to one guy that tows his 5th wheel with one. I don't know that I would try that but it was interesting to hear him talk. So far I'm very happy with the truck. But as with anything time will tell.
Old 10-19-2012, 10:41 AM   #16
Dave_Monica's Avatar
Easy enough to tell if it's got the max payload package. If it does the plate will show a GVWR of 8200 lbs...if it has max tow but doesn't have max payload the GVWR will show a GVWR of 7750 lbs.
With a GVWR of 8200 lbs, you'll have a true payload of close to 2000 lbs as the numbers I've seen indicate a truck weight of around 6200 lbs with full fuel and a couple of people.
Dave
Old 10-19-2012, 11:20 AM   #17
I checked and apparently it does not have max payload. Until now I didn't know about max payload. I guess my friend "tiny" will just have to stay home. Less groceries to take along. If you look hard enough you can usually fine a silver lining. :-)
Old 10-19-2012, 12:20 PM   #18
weiman1983's Avatar
Send a message via Skype™ to weiman1983
I have pretty much the same truck and tow a 318 Lacrosse and the truck does great. It is a big trailer but for the amount I tow, a 250 is just too much truck.
Good luck with the new truck
weiman1983 is offline   Reply With Quote
Old 10-19-2012, 12:46 PM   #19
Camper Less Camping
Cajun Po-Boy's Avatar
X2!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 06-16-2013, 07:19 PM   #20
At one time I had a tow unit. Before you make a decision try a 5th wheel unit on the highway with 18 wheelers passing.
Then you will know what to buy.
Go for the f250. My f250 with the complete tow package and the 6.2 gas and 6 speed transmission does the job. I pull a 30 foot Crusader.
Tarpon chaser 2 is offline   Reply With Quote
f150, f250
