Old 10-16-2016, 05:16 PM   #11
Canadian Member
itat's Avatar
I have a 2016 F250 SuperCrew with the 6.2L gasser, 3.73 rear end, towing a 7300# TT. I'm getting around 8.3 miles per US gallon (27 L/100 km) according to the driver info center.
The F-250 is a much heavier vehicle than the F-150 with a bigger engine so your fuel economy will definitely suffer but I've found it to be much more stable and now I'm within all the specs.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 10-16-2016, 05:30 PM   #12
Originally Posted by AJAbbott View Post
Ok all, guess I'm doing ok at 8.8 at 65-70 mph. I just thought I would get a little more out it.
I love the truck and setup was just wondering. Thanks for all the quick replies. Happy Camping to you all.
I just bought a Chevy 2500 6.0L gasser and I'm getting about the same. I've only got 2000 miles on it, so I'm HOPING it will get better as it breaks in.
My 1500 was getting 10 mph with a 5.3L, 3.73 axle and 4 speed tranny. I was hoping the 2500, with 7 more years of technological advancement, a 4:10 axle and a 6 speed tranny, would do at least as good as the 1500, but so far not looking good. But I am a lot more comfortable towing.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-17-2016, 07:49 AM   #13
DouglasReid's Avatar
How many miles to the gallon and when towing 8 thousand pounds what tire pressures are you running.
Seems like I got better mpg with my 2014 f150 than my new 2016 f250?
I had an 06 F250 with the 5.4 Triton engine. I got about 7.5 towing an 8000 fifth wheel and about the same towing one weighing just under 11000.
I just traded it for an 08 Silverado 2500HD with a Duramax engine. Haven't pulled it far enough to check the mileage on it though.
I keep the tires inflated to their maximum pressure on the truck and camper while towing. It is better for the tires and less likely to blow out one. It also improves the fuel mileage.
If you have SP tires on it you should not drive over 65 while pulling the camper. They heat up and it can cause blowouts. There are many many posts on this forum that wil tell you the same thing
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 10-17-2016, 09:23 AM   #14
WFD
My 1500 was getting 10 mph with a 5.3L.
But just think how much quicker you are getting to your destinations....at 10mph with your 5.3 it took you all day to get to your campsite!!!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-17-2016, 10:17 AM   #15
I pull a TT that is between 10k and 11k lbs. if I cruise at 75, I get around 6.5 to 7 mpg. If I keep it at 65, the mileage goes up to about 8.
My TV tires are running 75psi and my TT tires are running 80psi.
My truck is a 2016 F250 with the 6.2 and 3.73 gears.
325BH is online now   Reply With Quote
Old 10-17-2016, 10:51 AM   #16
Wobbles's Avatar
I have a similar truck setup with < 4K on it and I am pulling a TT weighing in at 6400 +- LBS. A recent 750 mile trip out got me in the 7 to 8 MPG range with headwinds for the first half of the trip at 63 MPH. The return trip was just over 8 MPG.
I am still learning the torque range in this new truck and around the 10K mark in it's life, I expect an improvement in MPG.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2015 Grey Wolf 26BH
Wobbles is offline   Reply With Quote
Old 10-17-2016, 02:00 PM   #17
I admit I have a lead foot. I also tend to keep it in 4th gear to keep the engine in its sweet spot rom-wise. This keeps it from downshifting every time I give it gas for a hill or to pass, etc.
With the 3.73 gears (instead of 4.10), 6th gear is too tall. 5th is OK for flats and around 60-65... but any incline or speeds above 65 and 5th can't pull it. 4th gear works nicely.
If I ever had a long trip, I might rethink things.
Old 10-17-2016, 02:19 PM   #18
Wobbles's Avatar
Mine is called the Petro Pig!
Funny thing I learned while on that trip was that, with Tow/Haul mode on and running with the cruise control on, a slight incline would drop it into fifth and it would stay there after the incline. I would then gently tap the gas pedal and it would roll up into sixth gear.
I am trying everything even some crazy stuff, just to learn what works best as far as the towing sweet spot goes. Honestly I do not give a hoot about my mileage when towing as I am going no matter what.
Having said that, I do realize my wallet does give a hoot.
Bob & Michelle
2015 Grey Wolf 26BH
f250, gas
