Old 12-02-2015, 12:25 PM   #1
F250 owners
Just starting my research and would like to hear from F250 owners on the 6.2L gas engine for towing. Any major problems or concerns with this engine?
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 12-02-2015, 12:38 PM   #2
B and B's Avatar
Hello Fellow Ontarian.
The difference in price between a Diesel and Gas was $4k on sale. I have the same service interval as Gas 12k, having a service plan the cost difference between gas and diesel is immaterial.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 12-02-2015, 12:43 PM   #3
Hey,
I was told the Diesel was 12K more and oil changes are crazy expensive. I would definitely consider that 4K price tag. Diesel's break down less often? I know they are great if you tow lots.
Old 12-02-2015, 12:59 PM   #4
OntarioFireFighter's Avatar
I have a '14 F250 gasser for a work truck, and a '15 F350 diesel as my personal ride...
The 6.2 tows fine; I use it to move around 8000# generators, and have no issues. It is thirsty - I'm getting about 17L/100km on it, when I'm not towing, but lots of get up and go...
Diesel seems to be getting better mileage; however the smaller tank is a bit of a pain (136L tank in the gasser, 96L in the diesel) - so the range is pretty much the same.
EDIT - my diesel cost me 2 k more then the 6.2 gasser would have... no idea what the maintenance will be like - they're both pretty new.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 12-02-2015, 01:07 PM   #5
KMP44's Avatar
Originally Posted by Doering View Post
Hey,
If you build a truck on Ford's website, the list price difference in the two is $8K. Whether a dealer might discount one more than other might vary, but I
don't think its common to find a $4K difference on 2 otherwise identical trucks. An optioned up Lariat 6.2 vs an XLT Powerstroke might be even less $4K difference.
But around here, diesel is $0.40 cents or so higher a gallon, so that negates a lot of the advantage of the better mileage. Oil changes are expensive with the diesel, and if you have major service after the powertrain warranty is up, it can run major $$.
And, the diesel engine is heavy - in the neighborhood of 600 pounds more than the 6.2, so the F-250 payload (depending on cab and configuration) is close to 3,000 pounds. Payload for an F-250 Powerstroke is more like 2400 pounds. So you get a ton of HP and Torque, but not much more payload than a 1/2 ton.
The diesel is a sweet option, but check out the Ford forums. There are plenty of happy 6.2 owners that tow. That 6.2 has been around a while and it has some nice advantages in lower cost, higher payload, lower maintenance.
I'm impatiently waiting for Ford to come out with the specs & pricing for the 2017 F-250. Was going to look for a new F-150 this winter, but decided to wait for the new Super Duty and give the 6.2 a hard look.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 12-02-2015, 02:14 PM   #6
leefl's Avatar
I have a 2016 F-250 gas, pulling an ultra-lite 5th wheel (7800 lb unladen, 9100 lb GVWR) and am happy with the setup.
No problems pulling the 5er so far, seems pretty stable. Gas mileage is generally in the 8-9 MPG range when towing (13 ish average when not towing).
Sure the diesel has more torque, and better mileage, but it's also $8K more up-front, and has a higher maintenance cost.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 12-02-2015, 03:37 PM   #7
jheacox1's Avatar
Same here except I have a 2015 250 gasser SRW and I'm 8058 lb unladen. Last time I weighed I was just over 9000 lb fully loaded for a 2 week trip. The 5th wheel and my truck get along very well.
2015 Rockwood Signature Ultra Lite 8281WS
2015 F250 Crew Cab
jheacox1 is online now   Reply With Quote
Old 12-02-2015, 03:54 PM   #8
Kenny kustom's Avatar
2015 F250 Crew Cab
8k empty, and 9k loaded with the fifth hooked up?
2017 Dynamax Isata 4
Old 12-02-2015, 04:23 PM   #9
Who Dares, Wins
doc73's Avatar
Different makes so I will shut up after this.. My LTZ was $3k over the cost of the same LTZ in gas. SO not that uncommon.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 12-02-2015, 04:24 PM   #10
jheacox1's Avatar
Yes sir, that's just the 5er weight. Sound heavy or light to you? No water in the FW tank.
2015 F250 Crew Cab
f250
