Old 06-23-2015, 07:52 AM   #1
F250 Power Stroke Brake Controller Gain Question
So I try to adjust my integrated brake controller per the Ford instructions pulling a Wildwood Heritage Glen 38' fifth wheel. Level road, 25 mph, apply trailer brakes only etc. Instructions say to basically increase the gain until the trailer wheels lock up, then back off from there until they stop locking up...Then that's the gain setting to operate by.
But, I run it all the way to 10 on the gain and still no lock-up. I'm not surprised as I figure this is alot to expect out of this entire system on a dry hot Summer road. Should I really be expecting these four big electrically braked tires to actually lock up on hot asphalt?
So how do I know what gain to leave my IBC on then?? To me the braking seems the same at 5-6 as it does up to 10 gain. It does slow and stop the entire rig at 25mph within a relatively short distance but again, I'm not sure what gain to leave it set at unless they should lock up of course and I got another issue I'm unaware of.
Brand new camper and brakes, I'm new at all this so the learning curve is plenty steep. I have heard this controller won't allow you to lock-up but others with the same tow vehicle do see their brakes lock and that info is also contrary to the gain setting instructions. Just wondering before I hit the hills, it is camping season and I hate to have my camper back at the dealer for service unnecessarily this time of year.
Thanks.
libertyteeth is offline   Reply With Quote
Old 06-23-2015, 08:27 AM   #2
Stormrider151's Avatar
I was able to lock my 30' Salem at 7.5 with my F150. I had it set for 6.5 after that and worked well. I just got a 27' trailer and the dealer turned it down to 5. While descending a long hill on wet pavement I started into a curve and applied the brakes. The trailer tried to push the back of the truck around. Why knuckle moment to say the least. It's now set back to 6.5. I like to feel a slight tug from the trailer when braking. Some may disagree with that but I really don't want to wind up jackknifed in a ditch.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-23-2015, 08:42 AM   #3
My experience with my brake control on my f250 is the same as you. Whether it's on 5 or 10 it feels the same.
LSUTiger is offline   Reply With Quote
Old 06-23-2015, 10:25 AM   #4
CWSWine's Avatar
I have a F350 with the same results as you. I can get to lock up on gravel but not on dry payment. I had a 28 foot trailer that I could get the tire to lock up but it was 3,500 lbs lighter than my current one. I can also get it to lock up and wet roads so I set mine on wet road and seems to work fine but I haven't had slam on the brakes yet.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-23-2015, 11:28 AM   #5
lesptr's Avatar
I had the same experience as you with my f350. I never could get the wheels to lock so I left the controller set at 10. Each time I pulled the TT I question whether or not the trailer brakes were working at all. Recently while going through the menus while the trailer was connected I found a submenu labeled trailer brake effort. It was set to low. I changed it to medium and when I applied the brake it felt like the trailer was doing all the braking. I backed it off to 7.5 and it "feels" good. Next outing I will find a parking lot to do the recommended procedure.
Edit,
I just checked and the trailer does not need to be connected.
Settings
Driver assist
Trailer brake
Trailer brake effort
Choose "low", "med", or "high"
My 350 is a 2015 so it may differ from your 250.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 06-23-2015, 11:35 AM   #6
Hank
I run my controller at 7.5- 8 pulling my 38' CC silverback 5th wheel with no problems. Stops perfectly. The ford brake controllers work on the amount of pressure applied on the truck brake as to limit the tire lock up on the trailer you normally have on the basic controllers. I always test mine by sliding the controller over manually before I leave anywhere and that is the only way I can get the tires to lock up.
hank7fd is offline   Reply With Quote
Old 06-23-2015, 11:59 AM   #7
lckeehne's Avatar
I have a 34' 5Th wheel and an F250 Diesel.
Mine is set at 7.5 normally and possibly 8.0 when running heavier tow.
I have never been able to lock up brakes but these setting work.
lckeehne is offline   Reply With Quote
Old 06-23-2015, 02:35 PM   #8
CWSWine's Avatar
Edit,
Settings
Driver assist
Trailer brake
I also have a 2015 F350 and just checked mine and it was set to low also. I set my for medium and we see next week when hookup again to the Passport America Rally we see it that makes difference. Thanks for the tip!
Old 06-23-2015, 03:04 PM   #9
I had similar on 2011 f250 and have been running it at 4-5 as braking seems good when I apply trailer by itself. I had never locked them up until a month ago when my breakaway lanyard got hung up on the hitch. They locked up good at 10 mph but then released as I slowly pulled to the curb to remedy the situation.
palmetto rogue is offline   Reply With Quote
Old 06-23-2015, 04:49 PM   #10
You guys that state it feels the same at 5 as it does at 10, what year model truck are we talking about? I have a 2015 f250 and 5 does not feel the same as 10. I run at 7.0. I can not lock up the trailer brakes either but by just using the trailer brakes only I can adjust the gain so the trailer does not push the truck. I stop on a small hill and release the truck brakes and use the manual control on the trailer brakes when I can feel the trailer brakes start slowing me down I add about .5 gain and try that. Adjust from there as needed.
twosocks is offline   Reply With Quote
brake control, controller, f250, power, brakes
