Old 07-26-2016, 06:52 PM   #1
F250 upgrade
Hi all! We just upgraded to a diesel f-250 from a 150. The truck receiver hitch is 3" taller on the 250. Wondering if all I have to do to my reese w.d.s is raise it that 3"? Thanks!
jwamiller is offline   Reply With Quote
Old 07-26-2016, 06:59 PM   #2
crunchman12001's Avatar
LOWER the ball on the hitch shank. The end result is the trailer is level, slightly nose low. Congrats on your new TV.
2015 F-250 FX4
Old 07-26-2016, 07:11 PM   #3
grhodes50's Avatar
Congrats on your new truck. I got mine a couple of years ago and love it.
I have the Equalizer hitch and only had to make some minor adjustments. I'm not familiar with the Reese, but I'll bet your adjustments will be minor as well.
Enjoy that new truck!!!
Gary & Trish
2018 Nights Camped - 5
Old 07-26-2016, 09:03 PM   #4
Thank you both for your quick responses!
Old 07-27-2016, 06:43 AM   #5
Make sure you have an adequate torque wrench when lowering the ball on the shank. The fasteners need to be torqued to a level most home mechanics can't obtain. Take it to a mechanic if necessary.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
Old 07-27-2016, 11:37 AM   #6
All one needs is a 1/2" breaker bar with a 2' cheater pipe on the end. Crank on it until you can't. Been doing it that way for years.
goduc is offline   Reply With Quote
Old 07-27-2016, 11:57 AM   #7
Glad you don't work on my vehicles.
Lee and Anne
Old 07-27-2016, 12:39 PM   #8
It ain't a cylinder head.
A 2' bar at the end will add 200lbs of force. The 3/4" bolt needs 260ftlbs of TQ. Most people can torque to 80lbs with a 1/2" breaker bar. Add 2' to it and you've got 280ftlbs of TQ. It ain't rocket science.
If you can change a flat tire on your trailer then you can torque to 100lbs as most lugs are between 90-120lbs. Add a 2' extension and it's way easier.
Old 07-27-2016, 12:45 PM   #9
NMWildcat's Avatar
How do you think the mechanic you are paying does it?
Scott and Liz - Southern NM
Old 07-27-2016, 12:47 PM   #10
LOL. As they say a "Fool and his money are soon parted".
f250, upgrade
