Old 09-26-2018, 03:07 PM   #1
F250 wdh hitch
Bought my TT a few weeks ago when I had a stock Chevy Z71 1/2 ton. The WDH I got was for that truck. I have recently bought an F250 which sits up higher and my WDH is too high for trailer to get on ball on its lowest setting. So my question is what WDH should I buy to fix this issue?
Kevin Riddle is offline   Reply With Quote
Old 09-26-2018, 03:15 PM   #2
Google B&W Trailer Hitches. They are quickly adjustable, and can be easily moved under the hitch to help keep your knee from being bruised. Good luck with it.
Schvarak is offline   Reply With Quote
Old 09-26-2018, 03:18 PM   #3
What WDH?
You may need a different drop for your WDH.
Bob
HappyTrav is offline   Reply With Quote
Old 09-26-2018, 03:37 PM   #4
You should be able to get a different taller shank for your hitch. Check with your hitch manufacturer, or if you have a good trailer place locally, see if they have one. Should be able to unbolt the hitch from the shank, and bolt it onto the new one.
Check with your hitch manufacturer for the proper set up procedures to adjust the hitch for your new TV.
katkt is offline   Reply With Quote
Old 09-26-2018, 03:40 PM   #5
I had the opposite thing happen when I went from a Tahoe to my F250 (the hitch on the Tahoe is in the back bumper instead of under it). You will probably have to take the hitch head apart and replace the drop portion. Make sure you follow the torque specs when you put it back together. I had to buy some large sockets and a wrench but who doesn't like a trip to Lowe's?
You will probably need something like one of these:
https://www.etrailer.com/s.aspx?qry=Drop+Shank
2017 Wildwood 28dbud - sold
2021 Keystone Cougar 316rls
2016 F250 6.7L - sold
2022 F450
bcintx is offline   Reply With Quote
Old 09-26-2018, 03:45 PM   #6
If it is a newer truck most 3/4 size have a 2-1/2" shank size,but you can use a reduction sleeve and buy a longer 2" shank for your MFG hitch,whatever that may be! Youroo! !
Old 09-26-2018, 05:38 PM   #7
Failure is my business
2Evil4U's Avatar
Yep. Order a longer shank. Had to do the same when I moved from half to one ton. Also upgraded to full 2.5" shank so I don't need the adapter.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
2Evil4U is offline   Reply With Quote
Old 09-26-2018, 07:11 PM   #8
clarkbre's Avatar
As said in your "flipping hitch" thread, turn the shank upside down so it points to the ground instead of upwards. This will buy you plenty of adjustment to work with your F250.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 09-26-2018, 07:23 PM   #9
Thanks all
f250, hitch
