Old 09-14-2014, 09:15 AM   #61
The only issue on that model was the injectors and by now I'm sure it has a brand-new set of injectors which took care of that problem. You have the five speed Allison which is still great and you still have the overdrive so it will tow no problem. As far as tires if you want fancy ones I would look into the Michelin LTX2s and if you want a lot of bang for the buck I would look at the Firestone Transformers HT's or ATs. The manager of the Ocala Firestone is a personal friend and I can get you 10% over cost on tires if interested. Enjoy.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 09-14-2014, 09:53 AM   #62
Also, seems like the truck came with everything already which is awesome for you. If it does not have airbags then I would definitely check into the Firestone ride right bags with the wireless onboard air. Makes it easy and if you go to a larger fifth wheel you are set. I found both on Amazon for a great price.
Doc
f350
