Old 03-08-2016, 08:07 PM   #11
Here is the description from the Chevy website. Sounds like it is a flush mount with bed caps when not in use.
Gooseneck / 5th Wheel Prep Package
Hitch platform to accept Gooseneck or Fifth wheel hitch. Includes:
  • Hitch platform with tray to accept ball
  • Drilled box holes with caps installed
  • Box mounted 7-pin trailer harness
  • Requires trailering equipment, spray-on bed liner and trailering mirrors
Think I will definitely order it based on every ones suggestions. Thanks!
cub22908 is offline   Reply With Quote
Old 03-09-2016, 12:08 PM   #12
Puck Model
Originally Posted by ferguson65 View Post
Had to order my Ford with it as none of the dealers around here stock trucks.............even duallies with it. They blame low take rate. How can you have a low take rate if you never have any in stock with the option? I wrote one dealer that kept bothering me a long email one night and told them they have no idea how to order trucks. Still never seen one on their lot 3 years later with the prep unless it was special ordered.
That said, I love the prep package in the Ford. I had a gooseneck when I bought the truck, sold that and bought the 5th. The hitch changeover is cake. Flat bed floor when out, super easy in and out. If it's a factory option, do it!
I was looking at Weslaco Ford in Weslaco Texas he had about 8 in stock I was getting service on mine F 350 Puck model just love it also just installed the New Demco Hitchhiker Slider 20K puck model. don't know how that is going to go but I have 3600 miles home so I guess I will find out.
selkirk awards is offline   Reply With Quote
Old 03-09-2016, 12:24 PM   #13
W5CI's Avatar
My 2015 RAM 3500 came with the Prep Kit, that was a selling point for me, but I did have to get a Picture frame adapter they call it to mount my existing Reece 16K hitch . Or I could have purchased the complete hitch for a $1000 more so i just got the adapter
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 03-09-2016, 12:24 PM   #14
JohnF's Avatar
I ordered it on my F350 and it is slick. Just slid my Demco slider into the holes and turned the pins to lock it in. No dealer needed. I ordered mine from Dyers.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 03-09-2016, 03:30 PM   #15
I recently purchased a 2500 ram with the 5th wheel prep package, highly recommend it. It is cheaper than aftermarket and looks tons better. Also with the ram it comes with a goose neck hook up.
Tude is offline   Reply With Quote
Old 03-09-2016, 03:52 PM   #16
Hoglou's Avatar
pull rite
I asked pull rite about fitment for a 16 srw 3500 duramax and here is what they said:
We are currently working on a solution for the Chevy prep package. I apologize I do not have a fit up for that system at the moment.
Thank you,
Inside Sales Representative
Pulliam Enterprises, Inc.
13790 E Jefferson Blvd
Mishawaka, IN 46545
1-800-443-2307*
Hoglou westGA
KM4HQQ 146.640mhz
Old 03-09-2016, 05:51 PM   #17
Can the factory kit be installed after you buy the truck? I just bought a 2015 f250, and have not had the mount installed yet, but the idea of no rails sounds great. I currently have a Reese 16k slider.
pacin is offline   Reply With Quote
Old 03-09-2016, 05:54 PM   #18
CWSWine's Avatar
Check out Turn Over Ball / B&W hitches. They have piece that goes under the bed of your truck for goose neck and the 5er hitch that will fit into the goose neck adapter. That's what I have and it works great...
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-09-2016, 07:45 PM   #19
ferguson65's Avatar
Yes it can. All it is, when it comes down to it, is a Reese Elite hitch. Buying it aftermarket you have the option to add the goose receiver or not. So pick up a Reese Elite and have the same as factory.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 03-09-2016, 09:23 PM   #20
Hutch333id's Avatar
My F350 DRW came with the factory installed 5th wheel prep and towing package. I recently had to take the hitch out to have the bed liner sprayed in. It took me only a couple of minutes to remove half a dozen pins holding it in. No rails so I can now use the full truck bed when necessary.
ID:	101499   Click image for larger version
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
5th wheel, factory, wheel
