Old 03-08-2016, 06:25 PM   #1
Factory 5th wheel prep package
Will probably have to order a new 1 ton diesel to get everything I want. What is the opinion on a factory 5th wheel prep? I like the idea but the sales people don't seem to know anything about it. I hate the thought of having someone I don't know start drilling holes in a new $60k+ truck to install a hitch. Are there any drawbacks to a factory prep package? I am tending towards the Chevy but haven't ruled out the others. Thanks again for your help. Dan
cub22908 is offline   Reply With Quote
Old 03-08-2016, 06:35 PM   #2
Not sure what the Chevy's package is like but I absolutely love the factory prep package that eliminates rails on top of the deck.
I can unlock, split my 24k hitch in 1/2 to make it easier to carry, and remove it in 10 minutes and have my truck bed back. I love not having visible rails on top.
If the Chevy hitch setup is the same, don't hesitate and get it. I'm using a curt hitch instead of the OEM one and getting it on etrailer saved me a ton of money.
Skyliner is offline   Reply With Quote
Old 03-08-2016, 06:39 PM   #3
BandJCarm's Avatar
Not sure Chevy has a prep package. I just, today, got a B&W Companion installed in new GMC Dually. It was put in by a local truck accessory shop that does zillions of them. I doubt the dealer would have a clue about it.
They did great, and it can come apart so that the head is removed, OR the entire thing can be removed, leaving bed of truck clean other than one hole and two U bolts for safety chains if a Gooseneck was ever used for anything.
BandJCarm is offline   Reply With Quote
Old 03-08-2016, 06:45 PM   #4
Major's Avatar
X2. I use the B&W Companion with the Ford puck mount and would not trade it for anything.
We ended up NOT buying our RV from a specific dealer simply because he did not know about the Ford puck mount hitches out there. Insisted there was no such thing. His ignorance cost him the sale.
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 03-08-2016, 06:53 PM   #5
CWSWine's Avatar
I would also get factory prep also and I won't let the dealership install the hitch, I would go to someone that does it more then few installs a year. I have the B&W Companion that doesn't take rails and love it. Besides it made in my state and we need the business.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-08-2016, 06:54 PM   #6
ferguson65's Avatar
Had to order my Ford with it as none of the dealers around here stock trucks.............even duallies with it. They blame low take rate. How can you have a low take rate if you never have any in stock with the option? I wrote one dealer that kept bothering me a long email one night and told them they have no idea how to order trucks. Still never seen one on their lot 3 years later with the prep unless it was special ordered.
That said, I love the prep package in the Ford. I had a gooseneck when I bought the truck, sold that and bought the 5th. The hitch changeover is cake. Flat bed floor when out, super easy in and out. If it's a factory option, do it!
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 03-08-2016, 06:55 PM   #7
I have been searching for info on the Chevy 5th wheel prep and coming up with nothing as it is brand new option available this spring for first time. It appears that it must work with curt hitches as that is what GM is offering as an option. I am curious if it will work with other hitches as well. I found that Ford and Ram publish a list of compatible hitches but can't find any info for Chevy.
Old 03-08-2016, 06:56 PM   #8
davel1971's Avatar
I just had to get new side brackets to use the Curt I already had. Great setup.
David & Lynn
Old 03-08-2016, 07:02 PM   #9
Jim34RL's Avatar
I am not sure on the Chevy/GMC package but the Ram 5th wheel package includes the inserts, punched holes in the bed with rubber plugs, and the 7 blade connector in the bed. This will allow some hitches to be readily adapted to the truck like the B&W Campion hitch.
See attached link:
Companion OEM - 5th Wheel Hitch - Fits Ram Puck System | Puck Mounted Attachment | THE B&W ADVANTAGE
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 03-08-2016, 07:46 PM   #10
I have a new 2015 Chevy 3500. My 5th wheel prep package is blunt cut wires to tie in bed harness. 2016 package also includes prep for turnover ball but I believe they are using reese products. I'm not knocking reese but I would recommend B&W system over reese. This is what I put in my 2015 with companion. I installed both myself. Not too hard but took me a whole Saturday for both.
2016 Wildcat 312BHX
2015 Silverado 3500HD
sugarjohnson is offline   Reply With Quote
5th wheel, factory, wheel
