Old 08-09-2016, 03:06 PM   #21
Originally Posted by TonyD View Post
I'm sorry but what is the point of posting this experience without sharing the name of the manufacturer?
If a product failed me and caused damage to my personal property, I would not hesitate to publicly name the company that was at fault.
X2. Having said that I am relieved that you and yours were not injured. Also you didn't mention the nature of damage to your TV and if the manufacturer is going to come up with the repair costs.
Safe Travels.
Tom Stillman
Vancouver, WA
2012 Forest River Wildcat Sterling Edition
2010 Ford F350 Super cab (With all the junk taken off) With H&S tuner and set of bags on the back.
tstillman is offline   Reply With Quote
Old 08-09-2016, 04:19 PM   #22
ccsvolsfan's Avatar
Glad you weren't going down road. Sorry you ended up with damage to equipment.
That said, I'm glad I have Andersen.
ccsvolsfan is offline   Reply With Quote
Old 08-09-2016, 04:31 PM   #23
Blaster 84's Avatar
Originally Posted by ValMelton View Post
we always do a test pull while keeping the front legs extended enough to keep any drops from hitting the truck. We also had to have our 5th wheel hitch repaired shortly after we bought it and had towed 2 times with it and a piece was broken. But I don't know the name of the hitch. (can't go check it for now) we were told by the dealership that we were very lucky to not lose the camper though. be safe and god Bless you with a safe trip home
I have always followed this same procedure. If I am testing an item to see if it works, I want a some protection in case it doesn't. This may be an extreme example, but it's like pointing a gun at someone, or at myself and pulling the trigger to test the safety.
Terry and Carol
Daytona Beach, FL
2013 F150 XLT, SuperCab, Ecoboost
2010 Rockwood 8285WS
Nights camped:
2014 - 57; 2015 - 91; 2016 - 171
Blaster 84 is offline   Reply With Quote
Old 08-09-2016, 04:36 PM   #24
41ford's Avatar
I'm sorry if anyone is upset with me for not naming the manufacturer, but in due time. I have no idea why it failed, the local RV tech doesn't know, but has seen it happen before with the hitch. I will be taking it to the dealer when I get home.
When I hook up, I always go to back of the pickup, look and make sure it's all correct. Both times, it was latched and a lock put in place. The 2nd time, had a RV park neighbor look it all over too, then tested it and it failed. He also watched me hook it up.
I'm lucky it didn't come off while driving.
I do keep the landing gear extended, but have kept the blocks under them. Think they will be coming out next test.
JR
2016 Forest River Heritage Glen 276RLIS
2012 Chevrolet Silverado LT 3500HD Duramax
Pasco, Washington
41ford is offline   Reply With Quote
Old 08-09-2016, 04:39 PM   #25
Taranwanderer's Avatar
I don't know about anyone else, but it's been my experience that if someone's product gets mentioned on the Internet in a bad light, it's more motivation for the product manufacturer to make it right, so that they can be seen in a better light when they fix it. I'd have no problem mentioning the product name in a case like this--it's more motivation for them to get you squared away. They can't sue you for speaking about your experiences with their product.
Good luck!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-09-2016, 06:15 PM   #26
Curt Hitch
I have a Curt hitch with a sliding bar latch, no way for it to come unlatched. Have been using it for eight years with no problems, would highly recommend.
donbledsoe is offline   Reply With Quote
Old 08-09-2016, 06:30 PM   #27
You might want to switch to a goose neck or Anderson hitch (gooseneck) - it will not fall off.
I used to use the typical fiver hitch also. Dealer even talked me into a slide hitch once. the ONLY time it slid was when I left the dealer and was driving back to the campsite pulling the fiver. Parked it on the side of the road and walked back to the dealer and let them have it. They got it fixed but it was never used on my 6 1/2 bed F250.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
johnruff is offline   Reply With Quote
Old 08-09-2016, 07:29 PM   #28
M109Rrider's Avatar
I've only every had 1 type of hitch. It has the sliding bar. Read several times where jaw types have popped open and dropped the trailer. Is there a positive benifit to the jaw type?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 08-09-2016, 07:35 PM   #29
Not having to get out and open the locking bar to hitch.
The 'jaws' simply open and then close on the pin.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-09-2016, 07:51 PM   #30
toslow's Avatar
i use a curt Q20 and it's worked well for me so far
haven a blast
toslow is offline   Reply With Quote
5th wheel, hitch, led, wheel
