Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Tech Talk > Towing, Hitches & Toads
Old 10-16-2011, 01:45 PM   #1
Brigitte
boubou's Avatar
failing tapping screws on Reese Dual Cam :(
Reese Dual Cam WD/Sway control hitch with 800 Trunnion bars (need to change to 1200 lbs I believe)
We went out on 2 short trips with it and today, I noticed that 1 of the bracket on the A frame holding the cam with 2 self tapping screws is loose
That concerns me a lot
I read great reviews about this WD and chose it specifically but now, very disappointed about it's early failure.
I've googled it and find other people with same problem but unable to find real solution.
anyone?
this picture is not mine, but this is basically what's happening
not mine by boubou1, on Flickr
Shasta Revere 21FBS LE
2010 Dodge Ram SLT 1500 QC 4X4 HEMI
Sheltie, Chihuahua and a Mr. Mutt
Kingston, Ontario
Days reserved 2012 (so far) 30 Days camped 2012:
boubou is online now   Reply With Quote
Old 10-16-2011, 02:49 PM   #2
too fast turbo sled
f1100turbo's Avatar
I installed a nut serts in mine to eliminate the self tapping screws.
You install them and squeeze them together with an installation tool then you have a blind hole nut.
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 10-16-2011, 02:56 PM   #3
Brigitte
boubou's Avatar
Ok, I don't know what these blind nuts are but will mention to the shop when I bring for repair.
How do these work? Fit same holes?
Should I get him to replace the other side to prevent future failure at the same time?
Kingston, Ontario
Old 10-16-2011, 03:33 PM   #4
too fast turbo sled
f1100turbo's Avatar
I would have them all replaced!
I will post a picture of them when I get home for you.
nut sert tool.jpg this is the installation tool
nutsert.jpg this is what the nut looks like
Ron and Amy Benhart
Old 10-16-2011, 04:19 PM   #5
too fast turbo sled
f1100turbo's Avatar
nutserts installed to give you an idea what they look like .
Ron and Amy Benhart
Old 10-16-2011, 04:27 PM   #6
Brigitte
boubou's Avatar
Originally Posted by f1100turbo View Post
Attachment 8651
Attachment 8652
So I guess these nuts are there to hold the plate in place and serve no structural purpose? is there a specific type or strength of nutserts?
I've heard of some of the Reese nuts used shearing (not what happened here, just bad thread I think)
Did you have that same problem or did you just not like the nuts included with the Reese DC ?
Brigitte
Kingston, Ontario
Old 10-16-2011, 05:19 PM   #7
too fast turbo sled
f1100turbo's Avatar
mine kept backing out or loosening . so I installed the nutserts and then applied red loctite to the threads of the bolt and installed them without anymore issues .
they would be just as strong as any not that you would put on the back side .
but since the channel is boxed in this is your only option .
Ron and Amy Benhart
Old 10-16-2011, 05:25 PM   #8
Brigitte
boubou's Avatar
Sounds like a great option
I've read about some guy who drilled through the back to access the nut and but a bolt in there. I don't want to drill the other side of the frame and weaken it so I like your idea.
I'll be calling the shop tomorrow and schedule an appointment
thanks again for your help
Brigitte
Kingston, Ontario
Old 10-16-2011, 05:33 PM   #9
too fast turbo sled
f1100turbo's Avatar
no problem !
I would not drill all the way through as well . The problem with that is to get the bolts tight enough you may crush the boxed in frame and we all know they are not very heavy to begin with . Which is why you are having the problem you are having . There is not enough material to hold your bolts securely.
let us know how it goes !
Ron
Ron and Amy Benhart
Old 10-16-2011, 05:52 PM   #10
Brigitte
boubou's Avatar
Sure will!!!!
I appreciate all your help
Brigitte
Kingston, Ontario
» Online Users: 582
118 members and 464 guests
2000XLifted, 4Jeeperz, 5Galvs, Adony, alphadog99, Andy R, Bandit114, Barney1, bean, bear17, biken201, bikendan, bobbygee, Borwick, boubou, brookside, Browndog, Busman1947, Cafjackracing, Cascade Bob, cdbus, chiro, chof16, comfun1, cyclepuck, dashonthedash, dasimser, ddavis662, ddemme, dec1952, deerslayer, Deputyseven, DGrissom, DonG, donn, DSN46, Dukejr, dummin4fun, elind, forthefunofit, FreedomTracker, frfan, gbpacker, GeorgieGirl, Gizzerd, Gman88, Gollum, Happy Vibe, iscotty123, isz, itat, JamesR, jasni, Jeep4Two, JJones, JoeR, Joker, jphillips1075, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, kjoh75, LFugate, lowbubba, Mad4sax, maggiek, McLuer, mhartzel, mia, Mr. Legato, mrmurph, MT28rk, mtnguy, NanaKaren, pandkm, pappcam, Pharmofish, PrairieBoy, punkaccountant, pwrplay, Ragin Cajun, Redheaded blue tick, ret2006, rkswyo, rob and lisa, Rogue69, Rsgtivr6, rstewart06, SabreMarv, SabreSam, Sailfish Bret, sbond, shineysideup, SimchaSabre, skippy31405, snowbrid, softwarejoe, southernsky, spike, Steve7575, texashatter, tgarner2000, Tincup13, Titleguy, tking1866, tmmar, torben, Triguy, viper48, VTX Al, wakamicamper, wayne anthony, whj77372, william.migues, woodchomper, wvfireboss
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
