Old 09-24-2014, 06:04 PM   #1
ShutterBugBev's Avatar
Fastway E2 Hitch
I've got to get a new ball mount hitch contraption for my truck. I discovered the Fastway E2 hitch and it appears to be a godsend. I don't have a lot of strength in my hands, and trying to hook up the sway bars with the chains and the equalizer and everything took me forever and took the joy out of hooking up and hitting the road. I'm looking at buying this setup. My 29' 2011 Rockwood Ultralite 2604 trailer weighs 7360 lbs. dry with all my stuff in it and I tow it with a 2014 Chevy Silverado 5.7 liter V8 350hp automatic transmission truck. It doesn't have the HD tow package. I never travel with more than a couple of gallons of fresh water in it, never with any grey or black. The hitch comes in 6,000, 8,000 and 10,000 pounds tow weight. I'm thinking of getting the 10,000 one but I'm not sure if I need it. It's only $15 more than the 8,000 pound one. I'm just wanting go know if anyone has had any issues with this hitch setup or if you are happy with it. Thanks so much!!
ShutterBugBev is offline   Reply With Quote
Old 09-24-2014, 06:13 PM   #2
jtstromsburg's Avatar
I had an e2 when I pulled a travel trailer. It worked great for me and, with a power tongue jack, hitching and unhitching was easy.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 09-24-2014, 07:24 PM   #3
fx2
For that weight I'd go with the equalizer brand 4 point
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 09-24-2014, 07:27 PM   #4
Platokidd's Avatar
X2 for sure get the 4 point with a power tongue jack.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 09-24-2014, 08:43 PM   #5
Looking at the Equalizer. Not sure what the difference is between it and the E2 . . .?
Old 09-24-2014, 09:40 PM   #6
Broke and happy
bobfa's Avatar
I had one on my travel trailer 21' at 4500 lb and I had the 8000 E2. It worked well with the power tonque jack. Need to get it properly setup.
bobfa is offline   Reply With Quote
Old 09-24-2014, 09:55 PM   #7
Platokidd's Avatar
The e2 has 2 friction points to help control sway. The 4 point has just that,4 points of sway control.
More is better
nights of camping
Seasonal
Old 09-24-2014, 10:18 PM   #8
Sgt. Schultz's Avatar
For the 4 point see
I suggest that with either setup the 8000 lbs set should be sufficient for the use you have -- too heavy a setup has other issues.
BTW I use the E2 unit - once the hitched and tongue lifted the bars slide on/off by hand no tools needed
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 10-08-2014, 12:10 AM   #9
I just switched over to the E4 hitch and am very happy with it, my dry weight is approx. 8000lbs and when I called Equalizer they suggested to go with the 10k hitch
I noticed that the trailer no longer sways and it also has helped with the bouncing due to the 4pts of friction as mentioned above
2013 Rockwood 8315BSS
Diamond Package
2008 Toyota Tundra CrewMax TRD
Scotsat is offline   Reply With Quote
Old 10-08-2014, 04:48 AM   #10
Platokidd's Avatar
ShutterBugBev , what hitch did you end up getting?
nights of camping
Seasonal
hitch
